Exhaust Ticking
Old Dec 15, 2003 | 10:32 PM
Toadfart's Avatar
Default Exhaust Ticking
My car makes a ticking noise after being run and I shut off my car. Started happening after I had my Carsound Cat welded on. Also sounds like my Cat is fubar cause I can hear the internals rattling around inside of it.
Any idea why it ticks? Could it be due to the clogged up cat? Thanks in advance.
-Dan
Old Dec 15, 2003 | 11:37 PM
sjteg's Avatar
Default Re: Exhaust Ticking (Toadfart)
i think it has something to do with the cat cooling off. My exhaust does that too where the resonator is, i think its pretty normal.
Old Dec 15, 2003 | 11:42 PM
svtec's Avatar
L D E S
Default Re: Exhaust Ticking (sjteg)
that's weird you said something about this.
my resonator rusted out and i had a new one welded in and my car ticks like a sun of a bish after i shut it down.
it sounds like a timebomb, but unfortunately it never detonates.
Old Dec 16, 2003 | 02:33 AM
AirWaveGT's Avatar
Default Re: Exhaust Ticking (svtec)
im pretty sure its just the metal cooling down that causes the ticking. started happening to me when i switched out exhausts
Old Dec 16, 2003 | 05:11 AM
jacobyb's Avatar
Default Re: Exhaust Ticking (AirWaveGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirWaveGT &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure its just the metal cooling down that causes the ticking. started happening to me when i switched out exhausts</TD></TR></TABLE>
That's all it is. It is just the metal expanding and contracting. It is not big deal.
Old Dec 16, 2003 | 08:59 AM
Toadfart's Avatar
Default Re:
What would cause the ticking though? Just trying to figure out if I had a leak because I did read somewhere on H-T that it might be a leak?
One more thing kinda off topic but not really actually. After I installed my Greddy 4-2-1 header, when I start my motor and rev to 3k rpm and let it fall to idle, it doesn't fall smoothly but pauses for a very slight moment near 2.5k rpm then 2k rpm again. Would this be due to a leak? Thanks guys for the input.
-Dan
Old Dec 17, 2003 | 01:03 AM
AirWaveGT's Avatar
Default Re: Re: (Toadfart)
when the exhaust heats up the metal expands. the ticking is the metal returning to its original shape
Old Dec 17, 2003 | 01:29 AM
1998_4dr_gsr's Avatar
Its completely normal unless you can't pass smog
Old Dec 17, 2003 | 07:58 AM
Timmy!'s Avatar
You could have a small hairline crack somewhere. I had this problem with this header on my civic. It turned out there was a crack in the header.
Old Dec 17, 2003 | 11:49 AM
Muckman's Avatar
Moderator in Chief
Default Re: Re: (AirWaveGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirWaveGT &raquo;</TD></TR><TR><TD CLASS="quote">when the exhaust heats up the metal expands. the ticking is the metal returning to its original shape</TD></TR></TABLE>
Old Dec 17, 2003 | 07:39 PM
Toadfart's Avatar
The tick also happens while i drive or when the car is running. So possibly no leak? I do hear a little hissing when I mash it in third going down my street sometimes.
Dan
Old Dec 18, 2003 | 12:40 AM
SHystrdyGSRtdy's Avatar
Default Re: (Toadfart)
all normal.......my header ticks... my mom's pathfinder's exhaust piping ticks like no other
Old Dec 18, 2003 | 01:48 AM
integrx's Avatar
New User
its normal, muffler shop told me after i got a custom catback, you probably didn't notice it while stock because the piping is smaller
Voodooboy520
14
Aug 14, 2006 01:52 PM
Feelseg
12
Apr 18, 2006 05:14 PM
EJ8 GSR-T
Oct 28, 2004 05:47 PM
AGENT 99
Sep 17, 2004 02:03 AM
ridiculous
13
May 8, 2003 10:13 PM
