Fastbrakes 11.1" Brake Upgrade
What modification is needed to fit the fastbrakes 11.1" re-drilled 4x100 rotors and ITR calipers onto DC2 Integras? I have read that you need to file down the calipers? Do I need any modifications to the caliper bracket?
Do you need new caliper brackets or will the stock one's work?
Or outside, depending on what your'e referencing off of. You need to file the mounting surface of the caliper bracket where it mounts to the knuckle to recenter the caliper on the rotor.
dayaftertomorrow
Acura TL, RL & ZDX
11
May 29, 2005 10:15 PM
JustLooking
Jul 9, 2003 09:01 AM
