d15a2 needs more power
Old Dec 15, 2003 | 07:07 PM
therealtime's Avatar
Default d15a2 needs more power
i have a 4wd civic "offroad beast" but as of now it has a puny carbed d15a2. until i have a few hundred to throw in a dohc zc or d16a1, how can i get more power from the d15 for very little money?
and since i am a "trial user" on the forum i cannot post more than 5 times in 24 hours yet so i will put another question on here: where can i find/ what kind of clutch should i get when i replace the tired stock one?
-tony
Old Dec 15, 2003 | 07:39 PM
Donkey85's Avatar
Default Re: d15a2 needs more power (therealtime)
you could try some iridium spark plugs,a drop in k&n filter, bacisly a good tune up. being carbed you could always bump the timing up a tad
Old Dec 15, 2003 | 08:02 PM
Magnum000's Avatar
Default Re: d15a2 needs more power (Donkey85)
Or try to get an Si MPFI setup. Will give you more HP's for fairly cheap.
Old Dec 15, 2003 | 08:48 PM
davens's Avatar
Default Re: d15a2 needs more power (Magnum000)
That's a tall order considering his engine is carb'd, not DPFI.
Not cheap and not easy.
He would have to upgrade his entire fuel system, tank forward to handle the 30+ psi fuel pressure when the stock was only designed for roughly 5 psi.
Then installing ALL the ECM components formerly controlled by the hydra-like vacuum box...this will involve several hours of labor(mostly wiring-bleah) and sourcing parts, preferably from a parts car.
Modified by davens at 7:37 AM 12/16/2003
Old Dec 15, 2003 | 11:54 PM
POSef's Avatar
Default Re: d15a2 needs more power (davens)
boost the **** out of it when you are ready to put the new motor in it!!!
Old Dec 16, 2003 | 04:43 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">That's a tall order considering his engine is carb'd, not DPFI.
Then installing ALL the ECM components formerly controlled by the hydra-like vacuum box...this will involve several hours of labor(mostly wiring-bleah) and sourcing parts, preferably from a parts car.</TD></TR></TABLE>
I agree. You would really have to love the car to do that kind of work. It would be much easier and probably cheaper in the long run to just get a FI car. I've never owned a pre 88 carbed Honda so I wouldn't have the slightest idea on what you could do in the quest for more power. I have came across aftermarket carbs and things while searching for parts before though.
I have a 90 Civic 4wd Wagon which came with the D16A6, already MPFI which made it a lot easier to install a new motor. I bought it with a bad engine and installed a D16Y7 from a 00 Civic DX. It took some work, had to make the original A6 oil pan fit the new Y7. It's designed different because of the 4wd tranny. I simply reused all the OBD0 components and now it's a solid running car again.
Old Dec 17, 2003 | 03:25 PM
i am trying the cheapest and least time consuming mods and swaps. like b16acrxer said in a previous forum post, it is my daily driver and i dont have another car. i am talking mods that could be done by 2 or 3 people in a weekend.
i like the carbed zc swap because it kept it simple. my only problem is locating the engine.
what cars could i look for at a junk yard that would have an engine that will bolt into the chassis and up to the 4wd tranny?
the car does pretty well with the 76 stock hp, but it tops out at 82 downhill with a tailwind and i occassionally have to downshift to make it up a hill. it kicked *** in the mud, but imagine where it could go with twice the hp. 140 is not a big demand, even for a carbed engine.
-tony
RebelriderMike
Classic Hondas
Nov 3, 2017 04:45 PM
ek1civic
24
Jul 22, 2008 07:00 AM
SVOboy
24
Jul 22, 2005 12:02 PM
bennjamin@ozhonda.com
Mar 20, 2005 03:44 PM
xMetal
Aug 15, 2001 09:25 AM
