CRX Si wiring harness in a DX?
Old Dec 15, 2003 | 04:41 PM
capbyrd's Avatar
Default CRX Si wiring harness in a DX?
ive read on here that it wont work. if not, i need to know for sure. thanks
Old Dec 15, 2003 | 06:30 PM
capbyrd's Avatar
oh yeah. ill be using the harness for an ls swap most likely. if not an ls then a b16a1
Old Dec 16, 2003 | 03:45 AM
VTECVillain's Avatar
Default Re: (capbyrd)
It will not work, that's the reason why you've probably read/heard about using the stock DX harness and doing the MPFI wiring. The shock tower plugs are different between the MPFI chassis (88-91 Si/HF) and the DPFI chassis (88-91 STD/DX). Basically in order to use the MPFI engine harness, you'll need to use the chassis harness also, which isn't worth it. Just use your DX harness and do the MPFI wiring.
btuned
Mar 5, 2007 02:17 PM
lrcrx90
May 29, 2006 08:14 PM
89-ef
Feb 25, 2004 06:42 PM
sporty240
Nov 18, 2003 06:13 PM
2ndGenREX
Jun 5, 2003 07:37 AM
