Radiator / can I use a AT one in my MT CRX?
Old Dec 15, 2003 | 01:51 PM
REDBARON's Avatar
Default Radiator / can I use a AT one in my MT CRX?
Just like the subject. My Toyo radiator took a crap, and I'm wanting to replace it. Can I use one from an automatic civic / Crx as long as it's Toyo.
Thanks.
Old Dec 15, 2003 | 01:56 PM
ElementMotor's Avatar
Default Re: Radiator / can I use a AT one in my MT CRX? (REDBARON)
I believe you can, the AT one has an extra line at the bottom but you should be able to plug it off.
Old Dec 15, 2003 | 01:59 PM
REDBARON's Avatar
Default Re: Radiator / can I use a AT one in my MT CRX? (EF8 ownz u)
That's what I'm thinking. Does anyone know for sure?
Old Dec 15, 2003 | 02:03 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Mine is a Modine for an automatic even though the car is a standard..
Most places just stock the automatic model and then use it in either application.
Old Dec 15, 2003 | 02:15 PM
Deetz's Avatar
Crazy Honda Guy
I know for sure, i have one in my crx. It's an aftermarket model that had the plugs for the AT tranny lines, I just ran a hose from one to the other, works great. Most aftermarket rads have metal end tanks on them as opposed to the plastic one on the oem units. (which are known for crackning)
Old Dec 15, 2003 | 05:28 PM
REDBARON's Avatar
Default Re: (Deetz)
So I can use either one as long as I plug the lines on the AT one, right?
Old Dec 15, 2003 | 06:36 PM
Hcivic88's Avatar
Default Re: (REDBARON)
I have an auto one in my hatch, I didnt even plug my lines or anything. I heard from someone else on here that I dont need to, cause nothing will come out of them, and they were right. Just put it in, put in the two lines that went into your manual rad. and you're set. No plugging/other hoses needed
Old Dec 15, 2003 | 08:16 PM
Magnum000's Avatar
Default Re: (Hcivic88)
YES YOU CAN!!!!!!!!!!!
Old Dec 15, 2003 | 08:38 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 &raquo;</TD></TR><TR><TD CLASS="quote">I have an auto one in my hatch, I didnt even plug my lines or anything. I heard from someone else on here that I dont need to, cause nothing will come out of them, and they were right. Just put it in, put in the two lines that went into your manual rad. and you're set. No plugging/other hoses needed</TD></TR></TABLE>
Exactly, the 2 holes are I think for ATF to run through and get cooled, no coolant, so no need to plug them.
Old Dec 16, 2003 | 05:00 AM
REDBARON's Avatar
Default Re: (blah13)
Thanks for all the help guys.
Old Dec 16, 2003 | 05:04 AM
VTECVillain's Avatar
Exactly, I also have an auto radiator. It's been in there for over 2 years, never plugged the auto holes either. It's really not necessary, but if you feel like it then go for it.
Old Dec 16, 2003 | 06:33 AM
IggDawg's Avatar
you can use the AT radiator. no biggie. don't bother plugging the holes as long as you never ever hook it up to an AT again. unless you want to do one hell of a flush job.
to boot, I think the AT radiator has slightly more capacity to deal with the extra heat from cooling the ATF.
-IggDawg
Old Dec 16, 2003 | 10:57 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">Just like the subject. My Toyo radiator took a crap, and I'm wanting to replace it. Can I use one from an automatic civic / Crx as long as it's Toyo.
Thanks.</TD></TR></TABLE>
I'm 100% sure the A/T and M/T rads are interchangeable.
The only only difference between the Toyo and the Denso is the way the A/C condensor fan mounts to it. So if you have A/C make sure you state which model rad. you have so the fans mount up the same way.
HTH
alpinegroove
26
Oct 23, 2013 09:05 PM
honda for life
May 13, 2006 10:50 AM
Ri5e
17
May 22, 2005 09:15 PM
HatchBox
Apr 15, 2004 06:26 PM
The Brown Kid
Aug 29, 2003 06:37 AM
