rear brakes on EF
Old Sep 20, 2001 | 09:04 PM
Cereal_Killer's Avatar
Default rear brakes on EF
looking for info in rear brakes for an EF civic. i want disks, heard i can use the ones of the CRX Si, or 91 teg's. what exactly will i need? or should i just snag the whole LCA off the Si or the teg?
Old Sep 20, 2001 | 09:09 PM
BoostedED9's Avatar
Default Re: rear brakes on EF (91efzc)
i belive you need the whole lca....
Old Sep 20, 2001 | 09:11 PM
Default Re: rear brakes on EF (ED9Hybrid)
for eithere model? so i can use the LCA's off the teg?
Old Sep 20, 2001 | 09:14 PM
BoostedED9's Avatar
my friend put the whole trailing arm from a teg on his crx.... so i guess either model would work....
Old Sep 20, 2001 | 10:02 PM
sicivic's Avatar
You will need the LCA's, rotors, calipers, brake lines, and parking brake lines off a 91 CRX Si or a 90-93 Integra.
Old Sep 20, 2001 | 10:04 PM
paulzy's Avatar
just the LCA and brake assembly or the whole trailing arm assembly?
Old Sep 21, 2001 | 03:43 AM
Davep's Avatar
All you need is the trailing arms, you don't need the LCA's.
Old Sep 21, 2001 | 07:00 AM
JohnnyM's Avatar
Default Re: rear brakes on EF (Davep)
Try this site... http://www.geocities.com/CapitolHill.../Disc2Drum.htm goes through all the parts and step by step how - to
Old Sep 21, 2001 | 08:18 AM
88 CRX SiR's Avatar
That makes sense to keep the existing 88 CRX LCA's cuz aren't the 90-93 Teg LCA's different...meaning you'd have to change rear shocks too? Correct me if I'm wrong.
I'm picking up the complete rear end Monday...comes with LCA's, trailing arms, rotors, calipers, lines...etc. If I don't need the LCA's off the Teg, that'll save me a few bucks!
So the rotors should bolt up to the 88 CRX LCA's? Can anyone expand on this?
Old Sep 21, 2001 | 08:39 AM
JohnnyM's Avatar
Default Re: rear brakes on EF (91TegRS)
You won't need the LCA for the swap. I Tried putting them in with the acura springs but the back end shot up about 3" due to the shocks. The Trailing arm is all you are going to need as long as it comes with the calipers, e-brake cables still attached.
Old Sep 21, 2001 | 01:51 PM
88 CRX SiR's Avatar
Default Re: rear brakes on EF (JohnnyM)
Thanks JohnnyM! I'll update you on what's happening with my car.
Old Sep 21, 2001 | 02:44 PM
RyanR's Avatar
You can use the rear brakes from any 90-00 Civic or Integra.
Old Sep 21, 2001 | 02:50 PM
JohnnyM's Avatar
Ok e-mail me if you need any help.....
Old Sep 22, 2001 | 06:16 PM
91ED7Si's Avatar
if the 91 crx si has disc rear brakes wny not the 91 civic si?
alx_90ef
May 24, 2009 06:52 AM
sohcvtec91hatch
31
Jan 4, 2007 02:16 PM
buckNasty
Jan 7, 2004 08:45 AM
Sleeper Sii
Sep 15, 2002 03:44 PM
Pissoff
Jul 20, 2002 04:01 PM
