98 b18b swap for 91 si
sup i just got a 1998 Ls b18b what do i need to convert it to obd0? or should i convert to obd 1? cause i dont obd2 to much to mess with all right hit me with sum information....
get an obd0 to 1 conversion harness.. someone on this board makes em for about 160. then just plug in your obd ecu... you have to run 3 wires to the engine but thats not a biggie.
I converted my harness by hand... every wire.... I was broke. thats the ONLY reason i didnt buy the harness adapter.
-x m d
-x m d
I have a 91 CRX with a 96 B18B1 and I used all OBD0 parts, it's very simple. You will need a 90-91 Integra PR4 ECU, 90-91 Integra distributor, 90-95 Integra alternator (for plug n' play) then reuse your Si injectors and resistor box. Just reuse your Si wiring harness on the motor, you will have to extend a few wires and rewire the coolant temp sensor which is no w on the thermostat housing as opposed to the back of the block. Other than that it's pretty much straight forward and plug n' play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">I have a 91 CRX with a 96 B18B1 and I used all OBD0 parts, it's very simple. You will need a 90-91 Integra PR4 ECU, 90-91 Integra distributor, 90-95 Integra alternator (for plug n' play) then reuse your Si injectors and resistor box. Just reuse your Si wiring harness on the motor, you will have to extend a few wires and rewire the coolant temp sensor which is no w on the thermostat housing as opposed to the back of the block. Other than that it's pretty much straight forward and plug n' play.
Yep thast how we put my Bros 96 b18b into his Si
</TD></TR></TABLE>Yep thast how we put my Bros 96 b18b into his Si
like he said . it`s GRAVY MAN ,GRAAAAAAVY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exodus1811 »</TD></TR><TR><TD CLASS="quote">can i still use the 98 intake manifold?</TD></TR></TABLE>
Yes you can.
Yes you can.
You'll need to extend your map sensor wires which is a plus anyways. Ive always liked top mounted Map sensors better for readings and no fish tank check valves for turbos
so i just need to extend my map wire? all the plugs from my Si harness will match up? use my si injectors rite? what about the 98 axles? i search but search doesnt come up with much... im lil lost still getting there tho keep tha info comin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exodus1811 »</TD></TR><TR><TD CLASS="quote">so i just need to extend my map wire?</TD></TR></TABLE>
Actually the stock MAP wiring will reach the MAP on the B18B throttle body. I installed mine without extending it, the wiring is tight but fine. It's been like that for about 3 years now, no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">all the plugs from my Si harness will match up?</TD></TR></TABLE>
You need to rewire the coolant temp sensor. It has moved from the back of the block where it is on your Si motor, to the thermostat housing on the LS. You'll need to change the plug to a normal 2 prong sensor plug. Other than that, you might need to untape a few sensor plugs and unloom them a little for them to reach the sensor, but that's about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">use my si injectors rite?</TD></TR></TABLE>
As long as you are going OBD0, then all you need to do is reuse the stock Si injectors and resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">what about the 98 axles?</TD></TR></TABLE>
You can reuse the 98 axles even if you don't use the hydro LS tranny. If you are using a B series cable tranny, all you need to do is change the driver's side tranny seal to a 94-01 Integra seal. If you are using the hydro tranny with the HASport EF hydro kit then no modifications are needed.
Wierd mine was way short on my 88 Si .
ddubtoille
Jun 28, 2009 10:49 AM
I Gotta Question
Feb 26, 2004 06:50 PM
