B18b A1 Injectors
Old Dec 14, 2003 | 08:32 PM
90_IntegraLS's Avatar
Default B18b A1 Injectors
I'm wanting a new set of injectors wondering what a good size improvement would be for a basically stock b18b. It'll have an intake soon and soon to follow will be the header. So want it to run as is but be able to provide the juice to push it later on. Let me know if you have some or even just a CC size suggestion as I can deal with carbs, but still need help learning the specifics for the fuel delivery as far as what is required for the engine and all that good stuff.
If you have a set you want to sell my e-mail is huh@gbronline.com or just leave a post with what size injector you'd put in along with the brand looking for a set around the sub $250 unless you can just convince me that something above that is just worth it :D
Thanks,
Jared
Old Dec 16, 2003 | 10:22 AM
Default Re: B18b A1 Injectors (90_IntegraLS)
Old Dec 16, 2003 | 11:31 AM
LODOSS's Avatar
don't waste your money. your stock injectors will be good for a long time... until y ou boost..
Old Dec 16, 2003 | 12:32 PM
arw321's Avatar
Default Re: B18b A1 Injectors (LODOSS)
You have a long way to go before you need higher flow rate injectors. If you really want, have yours cleaned and balanced at RC Engineering.
Old Dec 16, 2003 | 02:25 PM
mr.beeks's Avatar
Default Re: B18b A1 Injectors (arw321)
I did not see that you mentioned any other upgrades..
besides intake and headers.
the only time you are going to need them is when the ECU instructs the
injectors to dump more fuel and other factors as well like port and polish
plus higher cams
in wich 310cc's will be the upgrade of choice..
Old Dec 16, 2003 | 03:14 PM
Default Re: B18b A1 Injectors (mr.beeks)
K the main reason I'm wanting them is because my mpg has been going down hill slowly. So thought I could go ahead and get a set around 310 have a better spray pattern then stock and will be able to grow a little with my engine as well
TXGrunt
Dec 4, 2006 05:37 PM
Project_EK
11
Jul 24, 2006 02:41 PM
crxguy05sir
May 30, 2003 08:02 PM
bikeboy80
Sep 18, 2002 02:24 PM
Westrock2000
Jul 28, 2002 11:05 PM
