URGENT question bout camber kits
Old Dec 14, 2003 | 07:10 PM
boiwitwhitehond's Avatar
Default URGENT question bout camber kits
i have a 96 accord 4 door...i am gonna be droppin it with sportlines..1.8inch..what kinda degree would my camber kit need to be???.....anyone drop a car like mine and found out how much it was off???................or will i have to go pay for an alighment so they can tell me how many degrees im off by..then go buy a camber kit..and have to get an alighment again?
Modified by boiwitwhitehond at 4:24 AM 12/15/2003
Old Dec 14, 2003 | 07:23 PM
The_Todd's Avatar
Farts in the shower
Default Re: URGENT question bout camber kits (boiwitwhitehond)
Well you should probably get the camber kit and springs put on at the same time..its easiest, then get your alignment done, make sure you ask the shop if they do it for lowered cars, some shops around here don't know how to adjust lowered cars with camber kits....just ask them before, plus alignments are only 50 bucks. And will save you TONS in the future with tire and suspension wear.
Old Dec 16, 2003 | 01:14 PM
Old Dec 17, 2003 | 06:12 AM
fasterplease's Avatar
Most places will give a warranty on your alignment. You can lower the car, get it aligned and then decide if you need the kit or not. If you do, install it (takes less than an hour) and have it realigned with no further expense.
I got a solid 2 years on Z rated tires, 1.8" drop without a camber kit. I got slightly uneven wear but it was tolerable.
I only started getting abnormal wear when I went to a 3" drop (-2.1 camber in front). I got a correction kit after I went through a set of Yoks in 3 months. My tires still don't wear evenly but I'm getting much more longevity now.
Old Dec 17, 2003 | 10:49 AM
G-DASH's Avatar
You may want to wait and see how your car reacts to your drop. I had a 94 accord with a 2.5 drop and never needed a camber kit...that car is dead now, but my 98 coupe needed a kit with a 2.0 inch drop at the rear, go figure...
Old Dec 17, 2003 | 01:35 PM
adio's Avatar
Default Re: URGENT question bout camber kits (G-DASH)
be careful what camber kit you buy assuming you get one. otherwise, if you drive hard enough you wont need one.
Old Dec 17, 2003 | 03:14 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-DASH &raquo;</TD></TR><TR><TD CLASS="quote">You may want to wait and see how your car reacts to your drop. I had a 94 accord with a 2.5 drop and never needed a camber kit...that car is dead now, but my 98 coupe needed a kit with a 2.0 inch drop at the rear, go figure...</TD></TR></TABLE>
i agree you dont always need to rush and grab a kit..wait and have it checked if your are only going 1.8 you should be ok
Old Dec 17, 2003 | 03:27 PM
Old Skool's Avatar
Default Re: URGENT question bout camber kits (bagged93accord)
where's stew pidasso?
Old Dec 18, 2003 | 05:44 AM
White 99's Avatar
I've got Prokits on my 99, so I don't need a kit. But, three different shops told me that if I went Sportlines that I would need a kit. If your going Eibach, they sell kits that correspond with the springs you're using.
Old Dec 19, 2003 | 12:21 PM
layzi3boi's Avatar
i got a 95 accord and it butterfly like krazy after a 2.0 drop
find a shop that do camper work and they can bend it str8 with out camper kit
greyEG
Apr 20, 2014 01:20 PM
BJA86
11
Sep 2, 2007 01:00 PM
dom93hatch
Apr 19, 2003 10:26 PM
draco067
Feb 2, 2003 07:18 PM
631 Teggy
Jan 18, 2003 07:38 AM
