What needs to be done to convert my LS to GSR...
Old Dec 14, 2003 | 03:58 PM
tegasaurus's Avatar
Default What needs to be done to convert my LS to GSR...
Tranny. My 3rd gear in my LS is eating **** on me after a measily 140k miles So i need to know what i need to do in order to change out my LS 3rd gear to a GSR 3rd gear. And if i change out the 3rd, does 4th's ratio change also?
tia,
Ryan
Old Dec 14, 2003 | 04:01 PM
4U2NV's Avatar
Default Re: What needs to be done to convert my LS to GSR... (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">Tranny. My 3rd gear in my LS is eating **** on me after a measily 140k miles So i need to know what i need to do in order to change out my LS 3rd gear to a GSR 3rd gear. And if i change out the 3rd, does 4th's ratio change also?
tia,
Ryan</TD></TR></TABLE>
I wouldn't recommend putting a GSR third gear in a LS tranny... I doubt it will go prpoerly in synch with the other gears for a smooth power band... I would just replace it with an LS third gear set... However if it were first or second gear, you could replace with them with GSR gears because they have the same ratio...
Old Dec 14, 2003 | 04:58 PM
tegasaurus's Avatar
Default Re: What needs to be done to convert my LS to GSR... (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't recommend putting a GSR third gear in a LS tranny... I doubt it will go prpoerly in synch with the other gears for a smooth power band... I would just replace it with an LS third gear set... However if it were first or second gear, you could replace with them with GSR gears because they have the same ratio... </TD></TR></TABLE>
thanks for not helping out a single bit My goal is to have an LS 1st and 2nd (same as GSR) and a gsr 3rd and 4th, so basically its a GSR tranny with LS 5th gear.
Old Dec 14, 2003 | 05:01 PM
StyleTEG's Avatar
You can use just a gsr 3rd gear from honda, but it won't be the exact same since the LS has a different FD.
Old Dec 14, 2003 | 05:14 PM
J337_UNIT's Avatar
Default Re: What needs to be done to convert my LS to GSR... (StyleTEG)
ok wait a second!! 1st gear and 2nd gear are the same in both the gsr and LS trannys as far as im aware.
EDIT: WOOPS... i didnt understand the original post till now.. to me
Old Dec 14, 2003 | 06:06 PM
tegasaurus's Avatar
Default Re: What needs to be done to convert my LS to GSR... (J337_UNIT)
no so 1337 now are you? teh nub!!11
haha, ok, enough of that... blah, too much $ involved, LS will stay
Old Dec 14, 2003 | 06:15 PM
XtremeCarTuner's Avatar
If theres too much money involved, you could also try changing the tranny fluid to synchro mesh w/ friction modifier. The fluid isn't that much but it should help. But thats just my .02 cents.
Good luck with your tranny.
Old Dec 14, 2003 | 06:23 PM
fivespeedintegra's Avatar
instead of having to tear apart the whole tranny just to change a few gears, why don't you just pick up a used GS-R or SI tranny? less hassle
Old Dec 14, 2003 | 07:34 PM
trickout99's Avatar
hey, my ls third gear went out at around 150k miles. i just took out the trany and put a B16 trany, on, it was one of the best things i did to the car. it accelertes much faster than it used to.
Old Dec 14, 2003 | 08:11 PM
tegasaurus's Avatar
Default Re: What needs to be done to convert my LS to GSR... (trickout99)
Someone find me an SI hydo tranny or a GSR one for a decent price and i'll buy it. But everything i find that's in good condition is atleast 650 dollars. and im sure ic ould onyl get like 300 for my LS tranny with the slightly crunching above 6krpm 3rd gear
-Ryan
Toda Party
Sep 18, 2003 09:17 AM
Arsenal
Jul 20, 2002 10:32 AM
