Please Help!! Hid Install Problem!
Hey everyone. Someone please help me. I just installed my hids on my 97 CL, and it looks all messed up. I got the D2R ballasts with the D2R bulbs, and the beam shoots everywhere and not straight on the road. I tried every possible way to adjust it but finally figured out its not the adjustment. Anyone have had this trouble??? The bulbs seems to securely held in (I added a paper clip as a bracket). I tried just moving the bulbs at different angles inside the housing but still... Can someone check out the photos to see whats going wrong?!?!?! Thanks for all the help.
http://f2.pg.photos.yahoo.com/...stall
the metal rod thing...which i don't know what its called should be parallel with the ground and should be down
______
[______
---------- <----- down!
try it..i hope that helps
______
[______
also it is a housing NOT made for HID's so you will get light beam glare....you can't help it unless you use a projector lense
also it'll turn more blue later on...looks like it is a new set of HID's
i know the hids i got is a d2r... if i change it to a 9006 hid, would it help or will it still look f*cked up. I appreciate your info.
you will need the light cutoff piece that they sell in autozone.. its a shield for HID.. i forget what its really called..but its always used on d2s bulbs that are in housings that didnt come with HID
He's got D2R's so he doesn't need the light cutoff cuz it has it already and YESSSSSS
A 9006 WILL HELP ALOT BETTER THAN A UNIVERSAL ONE!!!!
Devine
Nov 28, 2005 02:31 PM
Toda Party
Aug 5, 2001 10:28 AM
