Cams and gears or throttle body & manifold next?
Old Sep 20, 2001 | 03:45 PM
Rob Dizzle's Avatar
Default Cams and gears or throttle body & manifold next?
Now that i have the I/H/E on. what is next?
The next logical step would be to do CTR I/E cams. and cam gears to tune them
Or should I get a bigger throttle body and intake manifold to let things breath easier?
Right now with a sub and spare in my car I have beat 2 rsx type s and I can easily hang with an itr
My main goal is to be able to beat a BMW Z3 3.0L from a rolling start or getting on to the freeway. the car has 220 hp and weighs around 3100lbs.
Any other ideas would be apreciated.
BTW, after I get my car smogged this month I will get a high flow cat, and I will install the cat back system
[Modified by bob46802, 4:52 PM 9/20/2001]
Old Sep 20, 2001 | 03:47 PM
MRXMUFFIN's Avatar
Default Re: Cams and gears or throttle body & manifold next? (bob46802)
i will say cam and cam gears, but manifold and tb are also good. i would really have to say do all 4 of them. good luck
Old Sep 20, 2001 | 04:26 PM
GTEater's Avatar
Default Re: Cams and gears or throttle body & manifold next? (MRXMUFFIN)
the cams and cam gears would be an easier install(2-3 hours)......i did TB and manifold first(all day), and just did my cams........i'd say both have about the same power gains
Old Sep 20, 2001 | 04:42 PM
ImportReview
Guest
Posts: n/a
Default Re: Cams and gears or throttle body & manifold next? (GTEater)
I think you should get Type-R valvetrain with some cams such as JUN type 2, Skunk 2, Crower or just CTR/ITR combo. After this...take my words...
GET A SKUNK 2 intake manifold.
And don't bother with your TB..TB won't do anything on that motor...you need compression to warrant a TB mod. Also, sell your header and get that new DC sports 4-1 JDM. YOu need a 4-1. 2.5" collector. And you need 2.5 inch exhaust.
If you have a decent mechanic...swap in CTR pistons...and CTR cams..with yoru current setup, you will gain probably 20 WHP from the piston/cam combo alone.
With the right intake and header with pistons/cams, your looking at around 185 WHP.
Jeff
JSPECSIR
30
Jan 26, 2009 09:23 PM
porter
Jan 27, 2007 09:57 PM
brawl
Mar 8, 2002 07:33 AM
masterxfob
Aug 30, 2001 08:18 AM
