Type R Oil Pump/Water Pump, any better than LS oil/water pumps?
Old Dec 13, 2003 | 06:42 PM
94lsboost's Avatar
Default Type R Oil Pump/Water Pump, any better than LS oil/water pumps?
My car needs a water pump now, and I was about to buy one at Auto zone, it has a lot of miles (170k) and I'm about to boost. I found a Type R oil and water pump on here for 40 bucks w/10000 kilometers on them. I think I remember reading that the type r oil pump was better than the ls...anyone fill me in? thanks!
Old Dec 13, 2003 | 06:46 PM
lustedp's Avatar
Default Re: Type R Oil Pump/Water Pump, any better than LS oil/water pumps? (94lsboost)
https://honda-tech.com/zerothread?id=647428
For your pleasure.
Old Dec 13, 2003 | 06:53 PM
94lsboost's Avatar
Default Re: Type R Oil Pump/Water Pump, any better than LS oil/water pumps? (lustedp)
Ok, so for the oil pump, I would have to cut into my plastic timing covers? (94 ls) And it is higher flow, so it's better.
And for the water pump, will it work? or is it beneficial?
Old Dec 13, 2003 | 06:56 PM
mr.beeks's Avatar
yes it will work since you are going to have a higher flow
that the turbo will benefit from it..
dont forget some minor mods have to be done thats all
Old Dec 13, 2003 | 07:00 PM
94lsboost's Avatar
Default Re: Type R Oil Pump/Water Pump, any better than LS oil/water pumps? (mr.beeks)
water pump is direct bolt on?? what minor mods? thanks!
Old Dec 13, 2003 | 07:05 PM
mr.beeks's Avatar
minor mods on the plastic covers so they will fit
like taking a little off the joint..
ifyou dont the screws will not line up..
Old Dec 13, 2003 | 07:10 PM
94lsboost's Avatar
thanks! and the water pump anyone?
Old Dec 13, 2003 | 08:36 PM
91tegrals's Avatar
dont you have to use a diff timing belt with the vtec oil pump and water pump...
Old Dec 14, 2003 | 11:08 AM
AzG35's Avatar
Default Re: (91tegrals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">dont you have to use a diff timing belt with the vtec oil pump and water pump...</TD></TR></TABLE>
Only the water pump. Use a LS water pump, otherwise you have to change your timing belt. A LS water pump only has 19 splines, a VTEC water pump has 22 and is much bigger.
boostedb18kid
Nov 10, 2007 02:10 PM
yaaj1320
Mar 3, 2007 08:53 PM
krazyhmongboi
Northwest (Sales)
Feb 17, 2007 07:59 AM
bankhead83
Jun 9, 2005 05:41 PM
VWkila
Jan 29, 2003 02:09 PM
