How often to flush radiator when water/water wetter is used?
Old Dec 13, 2003 | 06:39 PM
onyx00's Avatar
Default How often to flush radiator when water/water wetter is used?
Like the topic says. How often do I need to drain and replace with distilled water and fresh water wetter.
Thanks.
Old Dec 13, 2003 | 06:43 PM
ZygSpeed's Avatar
Default Re: How often to flush radiator when water/water wetter is used? (onyx00)
Good question, but in the future I'll be trying some of this:
http://www.evanscooling.com/main31.htm
Old Dec 13, 2003 | 06:57 PM
B2FiNiTY's Avatar
Just buy honda type 2 coolant. Premixed and all you need to do it add. I would do your radiator fluid every 30k miles.
Old Dec 13, 2003 | 10:30 PM
ejprimo's Avatar
Default Re: How often to flush radiator when water/water wetter is used? (B2FiNiTY)
water wetter contains silicates/ silicate free coolant is recommended for hondas.
but who knows if that really matters.
Old Dec 14, 2003 | 11:28 AM
all stock's Avatar
Default Re: How often to flush radiator when water/water wetter is used? (ejprimo)
i can't remember, but it's more often than stock now...i wanna say 20k, but that sounds wrong.
Old Dec 14, 2003 | 11:44 AM
StyleTEG's Avatar
Default Re: How often to flush radiator when water/water wetter is used? (zygspeed)
I flush and fill my coolant every 15k miles just to be sure.
Dropping a few dabs of soap into your coolant will break the surface tension and provide the same results as water wetter. An old trick Larry from Endyn posted awhile back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Running this now, its great. Pain in the *** to use though, since it can't have any water in it what so ever. So you basicly have to drain the radiator, block, and blow compressed air through the system to get all the water out.
SamC
Dec 8, 2007 07:55 AM
bmw626
Nov 16, 2006 10:29 AM
NA_H22_Ej
Jun 17, 2006 10:24 PM
onyx00
Oct 29, 2001 09:23 AM
94vteclude
May 18, 2001 01:58 PM
