turbo b16
i just got the t3/t4 turbo intercooler wastegate and bov i still need some odds and ends. i was told all i would need would be a fuel pressure reg and a new fuel pump since mine saw over 215,000 miles, got any suggestions
i didnt buy a full kit i got it off my friend who got a supercharger instead. im still in the works on geting the rest of the suff i dont really want to put it in till after the winter any way so i got time to get all the good stuff to do it right.
me and my friend are in the process of turboing a stock jdm b16 and the stock boost is set at 7 pounds. For fuel management we have a walbro 255 in tank fuel pump, and 440 injectors. For tuning we purchased a VAFC..theres also other things you might wanna get such as a recalibritaion kit, or maybe even a different head gasket to lower the compression.After it is tune and the injectors are in we are turning the boost up to about 10-12 pounds
allmotor89 is referring to my car...and no 8 pounds is not to much with the right tuning and the proper fuel to support it...do a lot of research that is my advice to you
good luck bro
good luck bro
i have about the same thing you are doing and i would pay the money for hondata it is worth the money in gold. i really like it and then take your car to a shop and dyno it with a bigger pump and 440's or bigger you should be fine at 8psi that is what i have been running for a while.
slowcrxsib16
Aug 27, 2006 10:43 AM
SkoundrelUSA
12
Sep 30, 2004 12:28 PM
