Diffrence in 91 Civic Dx and 91 Civic si heads
Old Dec 13, 2003 | 01:10 PM
hondafanatic1's Avatar
Default Diffrence in 91 Civic Dx and 91 Civic si heads
Just like the post says and
Wich piston can you put in a d15b2 other than the ones that come in it?
Old Dec 13, 2003 | 01:18 PM
onePOINTsix's Avatar
Default Re: Diffrence in 91 Civic Dx and 91 Civic si heads (hondafanatic1)
1. The DX head has a shitty cam are springs, not very aggressive and good to about 4500rpm. The Si head on the other hand has a very aggressive cam profile and stiff springs that can goto 7200rpm
2. You can only use D15 pistons in a D15, the wrist pin mounting point and the total height of the piston are differ from D15 to D16
Old Dec 13, 2003 | 01:25 PM
slowman's Avatar
I took way too long
Default Re: Diffrence in 91 Civic Dx and 91 Civic si heads (Sideout)
the pull of the d16a6 is pretty impressive for what it is!
i mine!
Old Dec 13, 2003 | 01:41 PM
kid-honda's Avatar
Both the DX and Si heads are the same cast but from what I have heard is only the cam is different, this is the first time I have heard of springs being different.
They may be since I have never looked into it.
Old Dec 13, 2003 | 02:15 PM
4sillypwr's Avatar
Default Re: (kid-honda)
I just started hearing in the past week or so that the springs are differant. Anyone got some specs?
-David
Old Dec 13, 2003 | 02:19 PM
91civicDXdude's Avatar
is anyone for sure about the actual size of all of the ports and everything?
I mean, a D15 head with a D16a6 cam and springs *IS* a d16a6 head?
Old Dec 13, 2003 | 04:28 PM
Default Re: (91civicDXdude)
So i can use d15z1 pistons in a d15b2?
Old Dec 13, 2003 | 04:45 PM
phatrick2332's Avatar
the head castings are all the same..they have the same casting number..but i dont kno it off hand.
As for the springs..im pretty damn sure there exactly the same, just a different cam. Becuz ive been taking my b2 springs/cam to 6k everyday for months and its fine.
And also, the d15 pistons are the same as the d16 pistons, u just might have clearance problems with the pm3 pistons becuz they have a taller compression height thats about 3mm more than the average d16 piston.
Old Dec 22, 2003 | 11:14 AM
likaciv's Avatar
Is that d16a6 a vtec motor?
What cams exactly will fit into a d15b2?? I have this motor in my sedan and it just aint cuttn it. Going from a built b18c in a 93 coupe to this is really depressing. I need more power!!!
Old Dec 22, 2003 | 11:47 AM
D.K's Avatar
D.K
Default Re: (likaciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likaciv &raquo;</TD></TR><TR><TD CLASS="quote">Is that d16a6 a vtec motor?
No. Stock, it's a SOHC, non-vtec motor.
stevescivic
Jan 20, 2007 07:32 PM
Gumbey75
Mar 11, 2006 12:47 PM
tgreaves
Nov 14, 2003 10:18 AM
No More Civic
Apr 30, 2003 12:24 PM
Todd00
14
Feb 22, 2002 04:58 PM
