EP3 shock removal
Old Dec 13, 2003 | 01:06 PM
al3e's Avatar
Default EP3 shock removal
it looks hell of like the RSX....but the steering ball joint thing...i cant get it to pull down... what do i have to do to get it off?
Old Dec 13, 2003 | 04:59 PM
97 TYPE-R 312's Avatar
Default Re: EP3 shock removal (al3e)
if you don't have a ball joint remover, smack the top of the shock with a hammer, that should jar it loose. I've noticed this an an issue on most EP/RSX's I've done.
-Victor
Old Dec 13, 2003 | 05:43 PM
al3e's Avatar
Default Re: EP3 shock removal (97 TYPE-R 312)
.. ...i realllly dont get it. its ******* got like 1600 miles on it... and its hell of hard to get off..
Old Dec 13, 2003 | 06:03 PM
B00STidDc5's Avatar
try a rubber hammer like 97 TYPE-R 312 said...it should work...
Old Dec 13, 2003 | 06:07 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e &raquo;</TD></TR><TR><TD CLASS="quote">.. ...i realllly dont get it. its ******* got like 1600 miles on it... and its hell of hard to get off.. </TD></TR></TABLE>
Thats why, the first time is usually the hardest.
Try this, hit both sides of the STRUT around the tie rod(dont hit the tie rod) with a hammer.
Then, loosen the nut flush to the bolt, so you can hit it upward with a hammer.
Now, you have to be CAREFUL not to hit the thread and dont hit it to many times.
If it doesnt come out the first 3 hits, then you get yourself a ball joint separator.
Old Dec 14, 2003 | 05:53 AM
fireant's Avatar
Default Re: EP3 shock removal (eg_nezay)
If there is a Harbor Frieght tool store in your area, they have a pitman arm/tie rod puller for $4.99... the exact same one that is 9.99 in most Autozone-type stores. It worked perfectly. Looks like a steel claw with a bolt in the middle.
Old Dec 14, 2003 | 05:57 AM
al3e's Avatar
Default Re: EP3 shock removal (hatch2k)
...ive been using the ball joint remover or whatever ..and i think i popped ... a berring or something whatever the little black thing around the joint is.. now theres like a lubricant all over the place.. anyother tips. its raining right now so i cant go out there right now but i will asap thanks for all the help guys
Old Dec 14, 2003 | 06:00 AM
crxagogo's Avatar
...go to your local autozone, advanced auto, etc and rent the proper tool. Return the tool get your money back. Simple, easy and a lot less likely to mess up something
Old Dec 14, 2003 | 12:32 PM
Jim Truett's Avatar
It looks like the boot is torn, and the grease is leaking out. Those wishbone style separators are pieces of ****. Get one of these:
You will need to replace that boot, and grease the joint.
Old Dec 15, 2003 | 04:14 PM
HondaRcB's Avatar
Default Re: EP3 shock removal (Jim Truett)
Yeah it's justa rubber boot filled with grease. Did the same thing on my ITR. And ofcourse the part had to be ordered as it wasn't a normally stocked item. I used the same type of tool you did
Old Dec 16, 2003 | 01:46 PM
UrbanTacticZ's Avatar
Default Re: EP3 shock removal (HondaRcB)
for future referance, you see the bar in the picture that you posted that connects to the drive arm?
shaped one coming from the left side of the strut? hit that with a hammer about 30 times (dont slam the heck outa it) just pound it normally and it will make itself loose. ive done suspension installs on 7thgen civics and rsx's and thats the way to do it without damaging anything. you'll see dont be afraid you wont break or damage anything. you'll know once its loose because you can simply tap the bottom of the ball joint assembly and it will easily lift out of the strut =]
Old Dec 17, 2003 | 11:00 AM
Dan GSR's Avatar
Default Re: EP3 shock removal (UrbanTacticZ)
get a tool like this
called a pitman tool
should be 20-30 bucks at autozone
Old Dec 17, 2003 | 11:57 AM
fireant's Avatar
Default Re: EP3 shock removal (Dan GSR)
Dan, thats the exact thing I was talking about that I got at Harbor Frieght for $4.99 It works perfectly, without even touching the ball-joint boot.
gRim06
Apr 21, 2007 09:01 PM
17
36
Oct 5, 2006 09:34 PM
3.point.2
11
Jun 15, 2006 11:03 PM
EG2Driver
Jun 6, 2006 08:50 PM
D50boy
Oct 26, 2003 01:57 PM
