VAFC II install
Old Dec 13, 2003 | 11:15 AM
Hairy Gorilla's Avatar
Default VAFC II install
Alright guys i'm putting in the VAFC II on my 99 GSR and I do not know where the TDC signal, VTC cam signal, and the VTM signal wires are. The Apexi manual does not show where these are. Can someone help me out?
Old Dec 13, 2003 | 11:19 AM
fergy016's Avatar
Default Re: VAFC II install (Tim Maryak)
what ecu# is that?
obd2b pxx
Old Dec 13, 2003 | 11:21 AM
threatcon13's Avatar
New User
Default Re: VAFC II install (fergy016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">what ecu# is that?
obd2b pxx</TD></TR></TABLE> 99 would be an obd2a wouldn't it, and i'm assuming its an p72. You didnt get the diagram manual w the vafc2?
Old Dec 13, 2003 | 11:23 AM
fergy016's Avatar
Default Re: VAFC II install (Threatcon13)
94-96 obd 1 (after 96 all cars are obd 2+)
97-98 obd2a
99-01 obd2b(considered obd3)
i believe your right p72. I don't know where to find the pin-outs for this obd computer.
Old Dec 13, 2003 | 11:28 AM
It does come with a diagram but teh diagram did not point out where those 3 wires went. It is really annoying. Does anyone have a Haynes maybe that shows where these go?
Old Dec 13, 2003 | 11:43 AM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">94-96 obd 1 (after 96 all cars are obd 2+)
97-98 obd2a
i believe your right p72. I don't know where to find the pin-outs for this obd computer.</TD></TR></TABLE> wrong....94-95 = obd1, 96-99 = obd2a, 00-01 = obd2b.
Old Dec 13, 2003 | 11:44 AM
Ok I found out the VTC signal is for I-vtec only. If you could help out with the VTM and TDC it would be greatly appreciated...
Old Dec 13, 2003 | 12:02 PM
OK, the TDC and VTC are for I-vtec only. I believe I found the VTM wire, although I think Apex messed up their wiring diagrams by year. I used this...
http://www.apexi-usa.com/produ...e.pdf
I think they meant the 96-99 to use the WH-2 manual while the 00-01 to use the WH-3 diagram. Does that make sense?
Old Dec 13, 2003 | 12:22 PM
fergy016's Avatar
yes that does completely. they didn't have the years corresponding with the diagrams correctly.
Old Mar 20, 2015 | 08:31 AM
cdl35's Avatar
I bought a vafc2 from a guy around the house and it didn't come with a wiring diagram I've been looking for 3 days and can't find one. It's going on a obd 1 gsr in a acura integra can someone help.
Old Mar 20, 2015 | 12:21 PM
B_Swapped93's Avatar
those things are a complete joke.... it completely by passes the ECU, the A/FR's along with timing etc change when it's properly ran through the ecu get a chipped ecu if you must but even in 03 these were a hack job thing. Amazed they are even around
JDM_WHR
Mar 21, 2007 02:41 PM
sublimenerd
Oct 23, 2006 12:37 PM
zexifiedlude
May 18, 2005 08:44 PM
jteasy
Sep 17, 2001 07:42 PM
jteasy
Sep 17, 2001 07:13 PM
