VAFC II install
VAFC II install
Alright guys i'm putting in the VAFC II on my 99 GSR and I do not know where the TDC signal, VTC cam signal, and the VTM signal wires are. The Apexi manual does not show where these are. Can someone help me out?
New User
Re: VAFC II install (fergy016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 »</TD></TR><TR><TD CLASS="quote">what ecu# is that?
obd2b pxx</TD></TR></TABLE> 99 would be an obd2a wouldn't it, and i'm assuming its an p72. You didnt get the diagram manual w the vafc2?
Re: VAFC II install (Threatcon13)
94-96 obd 1 (after 96 all cars are obd 2+)
97-98 obd2a
99-01 obd2b(considered obd3)
i believe your right p72. I don't know where to find the pin-outs for this obd computer.
97-98 obd2a
It does come with a diagram but teh diagram did not point out where those 3 wires went. It is really annoying. Does anyone have a Haynes maybe that shows where these go?
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 »</TD></TR><TR><TD CLASS="quote">94-96 obd 1 (after 96 all cars are obd 2+)
97-98 obd2a
i believe your right p72. I don't know where to find the pin-outs for this obd computer.</TD></TR></TABLE> wrong....94-95 = obd1, 96-99 = obd2a, 00-01 = obd2b.
97-98 obd2a
Ok I found out the VTC signal is for I-vtec only. If you could help out with the VTM and TDC it would be greatly appreciated...
Re: VAFC II install (Tim Maryak)
OK, the TDC and VTC are for I-vtec only. I believe I found the VTM wire, although I think Apex messed up their wiring diagrams by year. I used this...
http://www.apexi-usa.com/produ...e.pdf
I think they meant the 96-99 to use the WH-2 manual while the 00-01 to use the WH-3 diagram. Does that make sense?
Re: VAFC II install
I bought a vafc2 from a guy around the house and it didn't come with a wiring diagram I've been looking for 3 days and can't find one. It's going on a obd 1 gsr in a acura integra can someone help.
Re: VAFC II install
those things are a complete joke.... it completely by passes the ECU, the A/FR's along with timing etc change when it's properly ran through the ecu get a chipped ecu if you must but even in 03 these were a hack job thing. Amazed they are even around
sublimenerd
10-23-2006 12:37 PM
