B20Z to EG swap parts list...?
I am looking for a parts list for a B20Z to 92 EG. I found one for an EK but cant seem to find one for the EG's. Lemme know if you have one...
Pretty much everything from the EK parts list would apply other than the mounts. You'll need:
94-01 Integra driver's side mount bracket and mount
94-01 Integra rear mount bracket
Reuse your stock upper tranny mount
94-01 Integra/99-00 Civic Si/ front lower tranny mount bracket
Del Sol VTEC A/C bracket to retain A/C or 94-01 Integra/99-00 Si bracket if it will be used as a dampening mount
I heard somewhere that you cant use the B16 throttle cable, it has to be an LS or GSR cable? Sounds crazy to me but you never know. Is that true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 »</TD></TR><TR><TD CLASS="quote">I don't think you can use a GSR cabletoo long,but I could be wrong.</TD></TR></TABLE>
The GSR throttle cable will pretty much only work with a GSR motor or GSR throttle body and mount. It comes in from the opposite side then back to the right on the throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rockinfunzone »</TD></TR><TR><TD CLASS="quote">Alright well I have the throttle cable that came with my old B16 swap that I am going to use. That works right?</TD></TR></TABLE>
I believe that one is to short,best to use a LS cable.
atmosphere
Apr 19, 2006 02:30 PM
u2civic1
Feb 6, 2003 04:13 PM
