JDM LCA"S and UCA'S?
Ok I have found a set of Upper and Lower control arms front and rear, off of a 94 JDM civic hatch. Will they fit my 99 GSR? Are they a good upgrade? I want them so I can run JDM coilovers (probably Tein Flex). Also, what is a good price to pay? I did a search, and could not find specific info on the 94 Hatch, but read they are the same as USDM ITR ones, Thanks in advance.
EDIT* I found out the chassis code is EG6, if that helps.
Edit* I think I found the answer that they are the same, just hate to order and get the wrong stuff.
Modified by Crackerballer at 5:24 AM 12/13/2003
Modified by Crackerballer at 5:29 AM 12/13/2003
I wouldn't spend my money on them. If I were going to upgrade, then I'd go ahead and get the ITR LCA's as well as the ITR suspension and 5 lug conversion. It's not worth the trouble you're looking to go through for something that "might" be better.
So the EG6 are not the same as the type r? I did a search and this thread came up about them being exactly alike.
https://honda-tech.com/zerothread?id=593452
Please can someone directly confirm or deny these are the same pieces?
nikech1
Dec 8, 2006 11:34 PM
gsr98vtec
Feb 19, 2002 06:31 AM
