Cam gears... # of TEETH?
Old Dec 12, 2003 | 05:34 PM
xmd's Avatar
xmd
Default Mini me cam gear questions/ideas....
alright, the a6,y7,y8 and adjustable cam gears all have the same number of teeth, 38, and the same circumferance.
the a6 is 1/2 a tooth off from the y7/y8.
So this leads me to believe that for a mini me setup you could use the a6 gear.
Time the head with the y8 gear remove it and place the a6 gear on.
if im wrong about this people let me know. But it seems that this expensice adj cam gear wasn't needed.
Now I've heard that all 88-95 cam gears were the same.. I dont have a z6 gear on hand but if it is true then the z6 mini me wouldnt need an adj cam gear.
-x m d
Modified by xmd at 4:36 AM 12/13/2003
Old Dec 12, 2003 | 11:01 PM
91civicEX's Avatar
Default Re: Mini me cam gear questions/ideas.... (xmd)
on summit they had all sohc cam gears togethere. the one i got needed to be advanced 5 degrees to run at 16 degrees bdtc ignition timing.
91 civic LX
z6head d15 block
Old Dec 13, 2003 | 03:03 AM
USDM 4G VTEC's Avatar
on my Z6...i have a A6 AEM truetime adj cam gear
i have it 4.75 degreed retarded in order to really make it a 0 degree cam advance since the Z6 is 1/2 a tooth from the A6 motor
gramentz
Aug 31, 2013 09:44 AM
portenio78
Apr 23, 2006 06:26 PM
90efSI
10
Dec 16, 2005 09:31 AM
jjaskula1
Apr 3, 2005 10:50 AM
