need help!! cant get my d16z6 to start!!
ok guys i have a problem i cant get my f*****g z6 to start i bought a new p28 because i thought the one i bought with my swap was burned out... the car does have spark bought it does not get fuel and i dont know why i mean i have checked every thing i converted to mpfi and got a obd1 jumper harness but i need more help oh yea and the fuel pump does work but the injectors are not getting a signal i just dont know what else to do! thanks
if u have a multi-meter you might want to start checking your current right by the ECU and Right by the injectors. did the injectors work properly on the old motor right b4 the swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">does anyone know by chance how to check the resistor box?</TD></TR></TABLE>
Use a multi meter. Hold one point on the black wire and go through with the other point to check the other 4 wires. You should get 5-7 ohms on each.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 »</TD></TR><TR><TD CLASS="quote">Use a multi meter. Hold one point on the black wire and go through with the other point to check the other 4 wires. You should get 5-7 ohms on each.</TD></TR></TABLE>
ok when you do this do you check the connector that goes directly to the box or the connector that goes to the wiring harness... when i checked it directly to the box i got 6.3-6.4 ohms and when checked from the wiring harness i got around 12.3 ohms
ok when you do this do you check the connector that goes directly to the box or the connector that goes to the wiring harness... when i checked it directly to the box i got 6.3-6.4 ohms and when checked from the wiring harness i got around 12.3 ohms</TD></TR></TABLE>
You asked how to test the box. I told you how to test the box.
damn i've checked everything i just dont know what else to do man i bet i need to get new injectors but when i spray starter fluid into the tb it turns on for like a second but nothing if the injectors didnt work would it still spray
talagangpinoy
May 26, 2004 10:35 AM
