EF mounts on a 92 INTEGRA?
Old Dec 12, 2003 | 04:37 PM
Mentat Ghola's Avatar
Default EF mounts on a 92 INTEGRA?
I have Ef B series motor mounts. Will they work on a 92 integra LS? Will the axles work?
Old Dec 12, 2003 | 10:21 PM
Default Re: EF mounts on a 92 INTEGRA? (Mentat Ghola)
BUMP!!!!!!!!!!!!!!!!!!!!! AHHHHHHHHHHHHHH
Old Dec 13, 2003 | 04:39 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola &raquo;</TD></TR><TR><TD CLASS="quote">I have Ef B series motor mounts. Will they work on a 92 integra LS? Will the axles work?</TD></TR></TABLE>
I'm not sure what you are trying to do here, elaborate a little more on what you are doing: Which swap (???) into which year chassis (92 Integra?) would help.
EF B Series motor mounts meaning??? Aftermarket B series EF mount kit? or JDM Civic/CRX SiR factory mounts?
Again which axles???
Old Dec 13, 2003 | 05:32 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mentat Ghola &raquo;</TD></TR><TR><TD CLASS="quote">I have Ef B series motor mounts. Will they work on a 92 integra LS? </TD></TR></TABLE>
Simple answer.... no. First off, the position is different on the transmission & rear, and the driver side mount is not wide enough and will "flop" around in the DA chassis bracket. Never did it, but if you look at it, common sense will tell you that.
Old Dec 13, 2003 | 06:09 PM
Default Re: EF mounts on a 92 INTEGRA? (Newman)
thank you my friend
89civicracer
Oct 28, 2015 11:25 AM
pouponu
Jan 31, 2008 08:38 PM
disboilikehoy
Jan 29, 2005 11:00 PM
