OK guys I need you help on wheel offset for 00' R
Old Sep 20, 2001 | 07:59 AM
Type-ARR's Avatar
Default OK guys I need you help on wheel offset for 00' R
Will the Rota Slip Streams 15x114.3 with a 40mm offset work on a lowered 00' R? I thought the offset had to be 45mm but not sure ....... what do you guys think???
Old Sep 20, 2001 | 08:04 AM
Big Phat R's Avatar
Default Re: OK guys I need you help on wheel offset for 00' R (ITR-481)
You would probably have to run a narrow tire or else they might rub on the fenders. Stock offset is 50 mm.
Old Sep 20, 2001 | 08:08 AM
Flux's Avatar
Default Re: OK guys I need you help on wheel offset for 00' R (Big Phat R)
Damn, is everybody around here jumping on the Rota Slipstream bandwagon...?
Old Sep 20, 2001 | 08:30 AM
2fcknfst's Avatar
Default Re: OK guys I need you help on wheel offset for 00' R (Flux)
Yup.
I am a follower... not a leader.
Old Sep 20, 2001 | 09:41 AM
rainman's Avatar
What width is the wheel?
What tire width are you looking at?
What kind of negative camber are you running?
Have you rolled the fenders?
Old Sep 20, 2001 | 10:19 AM
cjb92's Avatar
Default Re: OK guys I need you help on wheel offset for 00' R (2fcknfst)
yep same thing happened when the c-8's were introduced, anyone remember that?
Old Sep 20, 2001 | 11:08 AM
Type-ARR's Avatar
Default Re: OK guys I need you help on wheel offset for 00' R (superflea)
Just answer the question,.........the wheels are 6.5' wide
rollinhonda3
13
Mar 29, 2015 10:49 AM
1337 Si
Sep 27, 2011 12:13 PM
meric0786
Jul 10, 2011 11:16 AM
xDicktonesx
May 25, 2005 10:41 AM
Ohlias
Sep 26, 2002 05:26 PM
