Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
99 3.2 TL is surgeing
Old Dec 12, 2003 | 06:00 AM
insomniac791's Avatar
Default 99 3.2 TL is surgeing
It is a 99 3.2 TL and sometime when idiling the rpms will surge from 500-2000
What could cause this? It does not do it all the time but is really anoying.
Thanks for any help
Later
Matt
Old Dec 12, 2003 | 07:09 AM
TEXN3's Avatar
Default Re: 99 3.2 TL is surgeing (insomniac791)
bad timing, ICV (idle control valve) is bad, injectors are clogged, a fuel delivery problem, bad grounding, etc...
its many possibilities. i have a feeling it is a timing issue.
are there any codes being thrown from the CEL?
Old Dec 13, 2003 | 10:45 PM
Ekay Nine's Avatar
Default Re: 99 3.2 TL is surgeing (texnteg)
O2 sensor???
Old Dec 13, 2003 | 11:38 PM
vigor5spd's Avatar
Check your radiator and fill it up.
Old Dec 14, 2003 | 03:12 PM
would teh radiator cause it to do that? Thanks for all the suggestions I will check them out. any other suggestions.
Later
Matt
Old Dec 15, 2003 | 04:08 PM
lazy bum shaughn's Avatar
If your car is still under warranty, take that bad boy to the dealership.
I heard about TLs idling weird though.
Old Dec 15, 2003 | 06:22 PM
nope no more warranty.. it sucks. I will try nd fix it myelf and if all else fails then to the dealership it goes.
Later
Matt
Old Dec 16, 2003 | 08:36 AM
JforJonathan's Avatar
did you do anything to it...like install anything? or did it just start doing it on its own?
Old Dec 16, 2003 | 02:01 PM
it just started doing it on its own. It is COMPLETELY stock.
Later
Matt
Old Dec 22, 2003 | 09:43 PM
azndng's Avatar
Default Re: (insomniac791)
does it go all the way to 2000 and stay there for a bit? or just bounce back down .. it might be just the weather, cold starts... mine idles at like 1500 on cold mornings... then when engine is warm..much lower. surging on my tach does happen.. but never 2k. just a thought.
Old Dec 23, 2003 | 07:52 AM
ludefreek's Avatar
sounds like the IAC or TPS to me. check those first. if there are any CEL, that would help a ton.
andyjt
Acura TL, RL & ZDX
18
Oct 31, 2011 12:35 PM
Thelugie42
11
Aug 6, 2011 09:45 AM
Jrichy
Aug 23, 2009 10:33 PM
invasian_boy
Jan 30, 2006 05:34 AM
99hcguy
Jul 18, 2005 07:09 PM
