car audio question..wierd winding noise
i just hooked up my dvd to my stock deck so that it plays from a aux. i have a sony cdxm610 and the aux is through a sony xa300. everything works fine but when i use the aux there is like winding noise. like from the speakers. it gets louder as i accelerate. does anyone know how to get rid of this sound?
Check your grounds. Make sure they are clean(i.e. no paint) you want the ground strait to metal. Also make sure you don't have any power wires running parallel to your output wire to you speakers from your amp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BadSiNCA »</TD></TR><TR><TD CLASS="quote">Check your grounds. Make sure they are clean(i.e. no paint) you want the ground strait to metal. Also make sure you don't have any power wires running parallel to your output wire to you speakers from your amp.</TD></TR></TABLE> If that doesn't work buy a ground loop isolator..
is3oo
Audio / Security / Video
Sep 14, 2003 03:10 AM
