96-00 civic cat question!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">ok correct if wrong but on the ex catalytic converter, it is 17in long and has two o2 sensor bungs, on in the front and one in the rear of the cat!?</TD></TR></TABLE>only one O2 sensor bung, the other is on the header
then what cat do i have??? both are on the cat and there is no bung on the header, do i even have a factory usdm type r header, the exahust and cat def look to be factory civic pieces??
sorry i have a b18c5 motor
you'll know if you have a factory exhaust manifold, the four dump high,normal to have a primary and secondary o2 sensor, the primary doesnt have to be on the header, it just has to be able to read all four cylinders.
p.s. just so you know the primary and secondary have different part #'s
is the first o2 bung on the down pipe in front of the cat?
the type r was never available in the us, except integras
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> ok so if it is, is the type r header longer than the gsr?? </TD></TR></TABLE>
yes
yes
jds_06
Jan 18, 2005 09:36 AM
EM1SiR
Nov 12, 2003 10:03 AM
hatch96
Oct 12, 2003 05:37 PM
