can i use ITR injectors in my EF?
Old Dec 11, 2003 | 07:48 PM
SimbaDogg's Avatar
Default can i use ITR injectors in my EF?
can i use the ITR injectors in my ef while still using my pr3 (non obd) ecu? i know that the 92+ are low resistance, and the 88-91 civic/teggy use the high resistance injectors (correct, or is this backwards). i think i was told that i could use them, all i had to do was take out the resistor box...but i'm not quite sure. can anyone help me out...
Old Dec 11, 2003 | 07:57 PM
civicSIracer96's Avatar
i was wondering the same thing. is this on a b16?
Old Dec 11, 2003 | 07:58 PM
redzcstandardhatch's Avatar
something different
Default Re: can i use ITR injectors in my EF? (SimbaDogg)
yes, just wire all the wires going to the resistor box together, that'll do it. you'll obviously need to wire in the ITR injector clips.....but that should do it...
Old Dec 11, 2003 | 08:42 PM
SimbaDogg's Avatar
Default Re: can i use ITR injectors in my EF? (redzcstandardhatch)
yeah, its on a b16...u know what, i'm just gonna avoid the stress and use my obd 0 injectors for now, and just hold on to the ITR injectors till lay-tor
Old Dec 11, 2003 | 08:43 PM
EG8R's Avatar
Um, last I heard ITR's don't use a resistor box.
I've heard they will work if you just bypass the resistor box....
F20b97AccordLx
Jan 18, 2014 06:02 PM
HARRY-DA
May 17, 2010 03:25 PM
Honda Sport
Jun 23, 2007 11:28 AM
dohdoh420
Apr 14, 2007 07:03 PM
Neukin
Jul 27, 2003 10:51 AM
