motor question...burnt main bearing..??
Old Dec 11, 2003 | 07:13 PM
Crab-Cakes's Avatar
Default motor question...burnt main bearing..??
i was going to pick up a 99 gsr block for 200
with a burnt main bearing...i am going to get it resleeved
with new rods and pitons but what does it mean that the
main bearing is burnt and is it fixed easy???
thanks george
Old Dec 11, 2003 | 07:15 PM
Crab-Cakes's Avatar
give me all the feed back you know!!
Old Dec 11, 2003 | 07:35 PM
Crab-Cakes's Avatar
anyone??
Old Dec 11, 2003 | 08:04 PM
Newman's Avatar
New User
Default Re: motor question...burnt main bearing..?? (doctor pressure)
A few things to check (kind of extreme, but always possibilities).... make sure the crank is ok and still good, make sure the main caps are not warped or a cylinder has sunk in result of it (even if resleeving, the deck might be warped but that's pretty extreme, but I've seen it happen), make sure the girdle holding the caps together is ok. Just a few things to look into, but mostly check the crank where it was on that specific main cap.
Old Dec 11, 2003 | 08:08 PM
Crab-Cakes's Avatar
i wont get the block..to much to worry about
thanks you...
Old Dec 11, 2003 | 08:23 PM
dogfood's Avatar
Default Re: (doctor pressure)
make sure that the crank isnt out of round, or tappered, if not you can replace the bearing and youre good to go, you might want to use a plastigage, thats an easy way to tell.
Old Dec 11, 2003 | 09:07 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (dogfood)
I doubt the crank is good anymore....if you're lucky, a crank grind will save you.
You may also need to line hone the mains of the block also
Old Dec 14, 2003 | 09:01 AM
Crab-Cakes's Avatar
sounds like too much...i passed on the block!
Old Dec 14, 2003 | 09:09 AM
1700anddroping's Avatar
for what its worth.i have a 95 gsr 72k complete bttom half,cross hatch looks very good.650
or you can email me.rootie16harvey@multipro.com
Old Dec 14, 2003 | 09:11 AM
yes i do know how to spell bottom,this dam key board is way to ******* small,for my big *** fingers
t_can
Engine Machining & Assembly
27
Jun 27, 2017 10:23 AM
Peter Brady onlyonweekndz
Nov 13, 2007 02:43 PM
poorman's type-r
Jan 25, 2006 04:45 PM
the.hamburglar
Nov 30, 2005 03:16 PM
jweller
Apr 1, 2005 07:02 AM
