do all stock vtecs engage at about 5000 rpm???
ok ive got a 92 ex with a sohc d16z6, because its only sohc, you cant really hear the vtec, therefore im not exactly sure when it triggers, the guy i bought it from said vtec triggers at 4200-4500. so who is right??? i always thought vtec engaged at about 5000
cheers
cheers
my b18c engages about 6k rpms... pretty late but owells.. who needs it early? the gears alwase stay between 6-8k rpms anywase...
my stock z6 engages about 5k something...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fraggle »</TD></TR><TR><TD CLASS="quote">is there really a vtec fluid or are you just givin me **** like tellin me my blinker fluidis low or my flux capacitoris goin out???</TD></TR></TABLE>
I guess you could consider engine oil the "vtec fluid." But most likely the guy was giving you a hard time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote"> or at least not 2 people that agree on anything!!
I think that statement is more appropriate.
Modified by Cookie at 6:31 PM 12/11/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">in 15 post not one RIGHT answer....or at least not 2 people that agree on anything!!
haha...</TD></TR></TABLE>
Its the ''guess when my vtec engages in question''
3200 Rpms? 4000 Rpms? 4500 Rpms? 6000 Rpms?
Or wait were all dumbass's but we have the same motor and vtec engages at all different times...
Ill sit back and watch let the ''pros'' get this one..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">D16Z6 VTEC kicks in between 4800 and 5200 RPM
end of story.</TD></TR></TABLE>
between??? how's that work - does it just do it when it feels like it?
i've heard 4800 on the dot. could you explain please.
but i know y8 is at 5500 for 100% (i can actually hear it
). plus, the stock tach is usually about 200rpm over, so if it's supposed to be at 4800, you won't be in vTeCH it till the tach crosses 5000 y0.
i've heard 4800 on the dot. could you explain please.but i know y8 is at 5500 for 100% (i can actually hear it
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">
you won't be in <U>vTeCH</U> it till the tach crosses 5000 y0.</TD></TR></TABLE>
gotta love that V-atAcK!
D16z6 - 4800 RPM
B18c1 - 4400 RPM
Depending on the ECU that you are running depends on when your vtec will engage not ur cams or motor. Why do you think people purchase a Hondata or rechip their ECU to change the VTEC Crossover
B18c1 - 4400 RPM
I believe it depends on the TPS...at WOT it opens at 4800...if you're at low throttle 5200 maybe? I know it varies, i'm just not sure what it varies on...ask spade
i've heard 4800 on the dot. could you explain please.</TD></TR></TABLE>
vtec kicks in @ 4,600
