Motor oil or tranny fluid?
How many quarts of fluid/oil does the tanny take? i heard that you can put 10/30 motor oil instead of tanny oil, is it true? if so, what do you guys think about putting Synthetic 10/30 motor oil?
If the tranny has any grinds in it put some GM Synchromesh in it. If you search on here you will find some very informative threads about it, it costs between $8-14 per qt. but its worth every penny and works awesome!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">takes 1.8 qts
and uses motor oil 10w-30</TD></TR></TABLE>
Now while everyone will recommend Honda MTF I have not once had a problem with regular old 10w30 now while yes I will probably be going to go with Honda MTF there still isnt any reason why regular oil doesnt work I mean if you read the manual thats even what they recommend themselves.
I put regular motor oil in last time and I noticed a difference......Its still fine but it was smoother with MTF.
Hmmmm....now that I think about it I think i put 5w-30 in.....maybe that's the difference. Either way, i'm changing back to MTF very very soon.
whats the best thing to use if your synchros are totally fugged..and you want to conserve them/avoid any grinds? use the 20w-50? or should i go w/ the gm fluid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg »</TD></TR><TR><TD CLASS="quote">whats the best thing to use if your synchros are totally fugged..and you want to conserve them/avoid any grinds? use the 20w-50? or should i go w/ the gm fluid?</TD></TR></TABLE>
If they are that bad, invest in a new tranny or a rebuild. Additives aren't going to help a serious problem.
I was told by one of the mech's at Honda that you should just use engine oil instead of tranny fluid in our trannies as the syncros can't cut through the oil fast enough if its too thin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
i know....thats what i'm plannning on doing. but i'm just looking for a motor oil that may be able to ease the load on the syncros
</TD></TR></TABLE>i know....thats what i'm plannning on doing. but i'm just looking for a motor oil that may be able to ease the load on the syncros
Since it doesn't look like you're gonna do a search, here's a link to the thread.
https://honda-tech.com/zerothread?id=549469
Don't waste your time with the oil, it will be a lot worse in the long run, the oil won't protect the gears near as well as tranny fluid, gm synchromesh is the asbolute best there is, a little expensive but it will save you money in the long run!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoody1982 »</TD></TR><TR><TD CLASS="quote">Don't waste your time with the oil, it will be a lot worse in the long run, the oil won't protect the gears near as well as tranny fluid, gm synchromesh is the asbolute best there is, a little expensive but it will save you money in the long run!</TD></TR></TABLE>
What Ive read a few times on HT also. Heard alot or Jdm trannys quit grinding with gM Syncromesh
how about if you can't use 2nd, 3rd, or 4th gears. seriously, it happened to my brother this weekend. he's only got 1st and 5th. btw, anyone got a 92-95 civic ex tranny?
young noob
53
Aug 21, 2007 04:16 PM
