F/S B18a darton sleeved block 84mm, ZEX 10lbs used flywheel, two JDM interment clusters
The block has never been used just got 4 blocks sleeved at one time and this is one never got used. It comes with a crank and the main caps. It is cut just under 84mm so you can get it cut to the final size of what ever piston you won’t to put in it. Asking $1200obo +shipping.
sorry the pics are fuzzy
The Flywheel like it said is a ZEX steel flywheel it needs to be resurfaced it is a little messed up where it bolts to the crank. The bolt worked there way out it doesn’t affect any thing I used it for a year after just thought I should tell you about it. I can post pics if you wont to see. Asking $150 shipped.
I have two JDM interment clusters one that redline at 8000rpm with an electric speed sender and it reads in km/hr it has no plugs. Asking $110 shipped
The next one redlines at 7000rpm it has a cable speedo it reads in km/hr to and it comes with plugs. Asking $110 shipped
Modified by EFrollingout at 12:15 AM 12/12/2003
Modified by EFrollingout at 8:59 PM 12/12/2003
Modified by EFrollingout at 9:00 PM 12/12/2003
15psi of fun
Dec 14, 2003 06:28 PM
