im pretty sure i blew my clutch
Old Dec 11, 2003 | 09:54 AM
kombo83's Avatar
Default im pretty sure i blew my clutch
let me know i was driving and i kinda miss gear i heard a clunk/grind or something but know the car wont get into gear even with alot of pressure i i can barely knudge the shifter into any gear.the car runs fine but wont move.
Old Dec 11, 2003 | 09:56 AM
AgentJam's Avatar
Default Re: im pretty sure i blew my clutch (kombo83)
I think if the clutch was gone you would be able to get the car in gear...just no grab when you release the clutch to drive away...
Old Dec 11, 2003 | 09:59 AM
JonGP4's Avatar
when u start the car does it make any kind of noise at all? sounds like eirther your tranny died or your flywheel came loose..(friend did that by over reving).. when a clutch gets burnt up you'll smell it..
Old Dec 11, 2003 | 10:11 AM
EL Vap133's Avatar
If it was a stock clutch or a sprung clutch, you might have broken one of the springs in the disk, that happened to me and it was the spring...
Old Dec 11, 2003 | 11:23 AM
kombo83's Avatar
i just got my car towed back to my house i only went like a block and that sH*t was $65!!!!!
Old Dec 11, 2003 | 02:37 PM
ITSTOCK's Avatar
Default Re: (kombo83)
make sure to check everything from where the shifter goes into the linkage and where the linkage connects to the tranny. If you sit in the car when its not running and everything seems fine, but it just doesnt go into gear it soudns like an issue with your tranny.
Old Dec 13, 2003 | 01:08 PM
CVC9216's Avatar
Default Re: (ITSTOCK)
Probably springs in the disk. Try to start the car with it in gear. If it moves while your cranking it, that's your problem. The clutch isn't disengaging. If you can't shift it with the engine off, might be trans. Drain the fluid and check it out
southernSCHEME
Dec 4, 2009 02:09 PM
ah789454
Feb 24, 2009 06:53 PM
slowdaintegra
Dec 21, 2005 01:31 PM
Hebrew-Hammer
Mar 24, 2005 04:08 PM
C4wrx
Oct 18, 2002 02:17 PM
