what' the best way to test electrical problems??? READ ON, HELP PLEASE...
Old Dec 11, 2003 | 09:09 AM
superrally's Avatar
Default what' the best way to test electrical problems??? READ ON, HELP PLEASE...
I noticed that my headlights and instrument/gauge lights will randomly dim out and flicker. anything I can do to fix that? what's the best way to test a problem like that? HELP please!!! Thanks in advance guys!
Car Info:
98 Civic with b18c1
I've been the only owner of the car, no floods, no accidents, nothin...
Old Dec 11, 2003 | 10:27 AM
TeamNextGenChris's Avatar
Default Re: what' the best way to test electrical problems??? READ ON, HELP PLEASE... (superrally)
check all your grounds,make sure battery terminals are tight and not corroded,check alternator belt tension,maybe troubleshoot ELD.try them and post back if they don't work.do you have a big stereo in your car or anything?
chris
Old Dec 11, 2003 | 10:30 AM
westsidejdmyo's Avatar
yeah grounds good start, also try fuses
Old Dec 11, 2003 | 11:49 AM
superrally's Avatar
Default Re: what' the best way to test electrical problems??? READ ON, HELP PLEASE... (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">check all your grounds,make sure battery terminals are tight and not corroded,check alternator belt tension,maybe troubleshoot ELD.try them and post back if they don't work.do you have a big stereo in your car or anything?
chris</TD></TR></TABLE>
stock civic stereo that's it. no amp, no stereo box, nuthin'... I'll try your tips this weekend. definitely appreciate the help!!!!
any other suggestions?
Old Dec 11, 2003 | 12:17 PM
EG-lowrider's Avatar
do you know how to do a voltage drop test?
it involves using a voltameter. kinda hard to explain in words, if not, go to a shop or mechanic you trust and tell them to do one for you or show you how to, thats the best way I know how to address your situation.
hope this helps, and good luck!
low'n slow
Jan 26, 2014 09:18 PM
b_serious
Feb 23, 2006 05:33 PM
85mm LS VTEC
12
Jul 26, 2005 04:13 PM
WhiteGSR95
Dec 12, 2004 12:25 PM
XEF-9X
Oct 14, 2002 08:40 PM
