Will EK Civic seats bolt right into an EG Civic?
Old Dec 11, 2003 | 07:07 AM
JJW's Avatar
JJW
Default Will EK Civic seats bolt right into an EG Civic?
Or did they change the bolt configuration?
Jim
Old Dec 11, 2003 | 07:17 AM
2000blackgsr's Avatar
Default Re: Will EK Civic seats bolt right into an EG Civic? (JJW)
You might have to swap rails, but they will fit.
Old Dec 11, 2003 | 07:23 AM
SloCivicHMM's Avatar
Default Re: Will EK Civic seats bolt right into an EG Civic? (96coupe)
swap rails and your set........but why??
Old Dec 11, 2003 | 09:58 AM
JJW's Avatar
JJW
Default Re: Will EK Civic seats bolt right into an EG Civic? (SloCivicHMM)
I knew someone would ask that.
I'm looking for a cheap, comfortable alternative to my stock seats.
I've tried GSR & del Sol seats and neither is any more comfortable than the stockers. The side bolster of the seat bottom sticks in my leg and cramps it up!
So I need something more flat like an EG sedan seat or maybe a stock EK seat. I'm open to suggestions
Old Dec 11, 2003 | 10:11 AM
civicboisi's Avatar
My .02 The Accords got the best seats...i could fall asleep behind the wheel sitting in those seats...
...don't know if they'll fit though. Good luck!
Old Dec 15, 2003 | 04:17 PM
ninety9ex's Avatar
Default Re: Will EK Civic seats bolt right into an EG Civic? (civicboisi)
what about the back seats?
Old Dec 15, 2003 | 04:25 PM
SofaKing's Avatar
Default Re: Will EK Civic seats bolt right into an EG Civic? (ninety3EX)
OK, heres the deal! listen to nobody else, becuase i have actually delt with this, lol.
You dont need to change brackets/sliders, ETC. when bolting in the EK seats in a EG. Bolt up the fronts of the sliders first(closest to steering wheel or glovebox) with whatever side you start on, then bolt up the rear slider closest to the door. the last one is the larger bolt that bolts to the rear sliders closest to the middle of the car or center console, youll see all you have to do is grind the hole in the slider bracket about 1/4 of an inch to make it a perfect fit. Mark that ish, pull em out, grind that extra clearance you need away. bolt em back in, in the same order i told you above and your done...
-done
Old Dec 15, 2003 | 04:59 PM
JJW's Avatar
JJW
Default Re: Will EK Civic seats bolt right into an EG Civic? (SofaKing)
Great post!!!
Now does that compromise the seat in any way?
Old Dec 15, 2003 | 05:17 PM
SofaKing's Avatar
im pretty sure between EG and EK the seat brackets are the same height so no issues there. Compromise,, what you mean? hurt it in any way? no way, youll see with that last bolt, the slider actually has plenty of room to work with. Wont be any weaker by any means.
--the only seat i can think of that will sit you lower than an EG or EK seat is the del sol Si seats, those definatly seat you an inch or more lower than most.
-james
Old Dec 16, 2003 | 08:03 AM
yes del sols sit your *** on the ground...I swapped in my EG rails and they are just *** low...I guess its not the rail but the seat.......
Old Dec 16, 2003 | 08:06 AM
JJW's Avatar
JJW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM &raquo;</TD></TR><TR><TD CLASS="quote">yes del sols sit your *** on the ground...I swapped in my EG rails and they are just *** low...I guess its not the rail but the seat.......</TD></TR></TABLE>
Agreed. I have del sol seats in my car now and they sit you much lower than the stock Civic seats and the GSR seats.
ChillinInTheDA
Dec 31, 2010 03:57 PM
jshaw23
Jul 26, 2010 08:38 PM
94DCTeg
Mar 17, 2010 01:55 PM
WABoostedb16
Aug 6, 2008 05:10 PM
808k20hatch
Mar 17, 2007 10:35 AM
