noise turning wheel
Old Dec 11, 2003 | 06:17 AM
green98civic's Avatar
Default noise turning wheel
when i turn the wheel coming out of my parking spot and also making turns there is a noise that is coming from the steering wheel. what is it?
Old Dec 11, 2003 | 06:43 AM
bseriesboosted's Avatar
Default Re: noise turning wheel (green98civic)
are you sure its from the stearing wheel. cuz if its not from the wheel it could be your cv's
Old Dec 11, 2003 | 06:44 AM
REDBARON's Avatar
Is the noise coming from your steering wheel, or your CV joint (axle)? Is it kinda like a clicking noise, that only happens when you are turning?
Old Dec 11, 2003 | 07:34 AM
BdoubleU's Avatar
If the noise is a clicking or knocking then these other two gents are right, it is one of your CV joints(axels.) If it is "squeakier" (for lack of a better desc.) then I've found that the tie rod ends and steering rack can create this sound when worn. Another thing is the wheel bearing. To tell if it is the wheel bearing vs. tie rods, jack the car up and wiggle the wheel side to side. If you feel play side to side only then it is tierods or rack, if the wheel also wiggles up and down (top to bottom) then your bearing is shot.
Good luck
Old Dec 11, 2003 | 07:51 AM
insomniac791's Avatar
unless maybe you have LSD mine makes all kinds of clicking and moaning noises when I turn slowly.
later
Matt
Old Dec 11, 2003 | 10:26 AM
EJ2-Fluffy's Avatar
Lube up them CV joints!
ApatheticAccord
Mar 12, 2016 01:48 PM
jonathan13
Feb 11, 2011 04:22 AM
DB8_TEG
Nov 18, 2005 11:32 AM
EFz6er
Feb 24, 2005 05:57 AM
Fatty_1775
Jul 1, 2004 10:09 PM
