Pics of my CRX at the drag strip. Destination: GUAM
Here are some pics of my car, coming all the way from Guam. Didn't get a chance to run because of rain.
Check it out:
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wMjIxMzkyNnM0MTNkZmQzMXk1NDE%3D [/IMG]
Check it out:
i have a small battery from Hawker PC-680, if im not mistaken. Still figuring out how to mount it and stuff. I'll be putting an intake pipe there as soon as i get the battery squared away.
I'm just runnin 1 o2 sensor for now. What should I do? Go with the chipped ecu or weld another bung? How much difference would it make and would I feel noticeable gains?
with stock PR3 or PWO ecu no chipped with 1 O2 sensor only? You'll notice a difference if you correctly add in the second one. Most of the guys with the 1st gen b16 have problems with the O2's because they have them either reversed or spliced together. Does is run rich or bogg at all? I had mine reversed and it through some high numbers when I had it smogged. Once I connected them correctly I passed, after I had a new cat installed. Big difference in performance. Or just chip the ecu, I'm running the Mugen race program, which deletes the secondary O2, and according to Katman I can relocate the primary O2 near the cat (the common location).
Might I also sugest moving that coil closer to the dizzy. You may be loosing some spark with that long *** coil wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">Might I also sugest moving that coil closer to the dizzy. You may be loosing some spark with that long *** coil wire. </TD></TR></TABLE>
Yeah I second that, 18" is the max that I was always told for the coil wire.
great pics, too bad you didn't race. looks like a great setup you got in your car...good luck and keep us posted
Yea, our drag strip has been operating for awhile now . Our fastest cars are hitting 9's. The legal drag scene on Guam is still fresh. And there's absouletly room for improvement. I'll take more pics at the next race.
Modified by avscrx at 3:55 PM 12/24/2003
Modified by avscrx at 3:57 PM 12/24/2003
Guam is located in the Pacific Ocean between Hawaii and Australia. We are a US territory and we are where America's day begins......
BearsEK-KMSU
34
May 23, 2007 02:42 PM
SlowWhiteEvo
Mar 6, 2006 11:28 AM
