What else do I need for my all motor D16 setup?
Old Dec 10, 2003 | 09:00 PM
mike6024's Avatar
Default What else do I need for my all motor D16 setup?
- D16A6 block
- D16A6 ported head
- OEM (but maybe ported) IM
- I/H/E
- ZC pistons and rods
- JE piston rings
- Exospeed SR909 or Crower Stage 2 street/strip camshaft (or similar)
- new rod bearings
- metal head gasket
- ARP head bolts/studs
- Skunk2 cam gear
- maybe underdrive/lightweight crank pulley?
- maybe new valve springs?
CR would be 11.3:1 (or maybe higher depending on head gasket)
Do I need anything like bigger fuel injectors or anything else I forgot?
And what should I get to tune it? Would a SAFC suffice, or should I use ghettodyne or Hondata?
Old Dec 13, 2003 | 10:46 PM
mike6024's Avatar
Default Re: What else do I need for my all motor D16 setup? (el terror)
Does a B16 TB fit a D16? And would I really need those from a GSR? How about maybe just an FPR?
Something else I read about recently, would I have a problem with valve clearance with those PM7 pistons?
Old Dec 13, 2003 | 11:10 PM
Vinceg99's Avatar
You could stick either the Z6 or Y8 intake manifold on it (They both flow better than the A6 IM) and then bolt any B-series TB on it that you would like. And no an LS TB doesnt bolt up to an A6 IM without mods it will NOT bolt right on. Oh and I tried it thats how I know.
Old Dec 16, 2003 | 11:02 PM
mike6024's Avatar
How essential would new valve springs be to this project? On that same note, should I got all new valves too, or would that not help any?
And I'm still a little concerned about valve clearance...
ShakeTheEarth
Feb 2, 2015 11:38 AM
purplerain11
25
Oct 28, 2012 10:28 AM
bakomack
May 4, 2010 07:48 PM
949
Oct 29, 2009 08:09 AM
T.Slick
Mar 4, 2006 05:10 PM
