H22 Eg Intake manifold Removeable?
HI
Just wondering if any of you are able to remove/install the complete intake manifold with the motor in the car (EH) using HCP mounts? Just curious since all I'm waiting on to install the engine is a intake gasket, but if I can install everything else then I'll do it before I get it.
Thanks for your time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EK »</TD></TR><TR><TD CLASS="quote">did you get the pakage?</TD></TR></TABLE>
No, not yet. I was at my dad's house about 11:30 this moring and nothing, I hope by the time I get off work it'll be there.
Yup same here. I couldn't completely remove the intake manifold when I tried to cut a hole for my egr port in my hondata gasket. I could only slide it partially off. I have an HCP kit. It's a really tight fit back there.
all you guys need to do is unbolt the rear bracket off the trans then you can pull and rotate the motor forward with enough room to change manifolds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio »</TD></TR><TR><TD CLASS="quote">my mounts don't move....</TD></TR></TABLE>even with solid mounts the polyurathane will give a little, try it though cause i have solid mounts too and it moves enough to get the IM out.
misterpsycho
Jan 11, 2007 11:16 AM
perseverance
Oct 31, 2006 10:15 PM
RTW DC2R
Jan 21, 2005 04:36 PM
