turbo for b-series junkyard kit
yea that doesn't really help me. i already know that the t3/t4 turbo is good for the b-series. i just don't have that much cash and i was wondering which turbo i could pull of a car from the junkyard would be the best for a b-series engine.
none, the "best" turbo would be properly sized for the engines flow.
But if your going to go with a used turbo from a junk yard, get a larger t3 from either a saab or mustang..(i believe)....don't get the smaller t3 (.42 cold .48 hot)....be carefull using a used turbo, it may be more work then its worth if you cant find a good one
I am pretty sure you can use a turbo from just about anything. I know there are some people on here using turbos from Saabs and Porsches. I think DSM eclipse/talons will work also. Do a search for "budget turbo" in the archieves.
T3 from a thunderbird, svo mustang, or XR4Ti.
As long as its a .60 compressor you should be fine.
I made 237whp on 8psi with a .60/.48 T3.
B16 that is.
Good luck.
What are you planning to fuel it with?
B16 that is.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leed »</TD></TR><TR><TD CLASS="quote">T3 from a thunderbird, svo mustang, or XR4Ti.
B16 that is.
Good luck.
237 at 8psi- damn! for a junkyard turbo
B16 that is.
Good luck.
so the larger trim t3 60 trim did they come on any other cars than the mustang? i htink it really is going to be hard to find this one. i didn't see any 80's mustangf at the junkyard.
JDM TEGG
May 28, 2009 05:43 PM
turbohf
Northwest (Sales)
Mar 23, 2008 03:14 PM
