turbo for b-series junkyard kit
just can't find any definite info on which turbo to use. i going to put it on a stock b17. i am only looking to boost up to 10 psi max.
yea that doesn't really help me. i already know that the t3/t4 turbo is good for the b-series. i just don't have that much cash and i was wondering which turbo i could pull of a car from the junkyard would be the best for a b-series engine.
Re: (b1788crx)
none, the "best" turbo would be properly sized for the engines flow.
But if your going to go with a used turbo from a junk yard, get a larger t3 from either a saab or mustang..(i believe)....don't get the smaller t3 (.42 cold .48 hot)....be carefull using a used turbo, it may be more work then its worth if you cant find a good one
Re: (b16ahybrid)
I am pretty sure you can use a turbo from just about anything. I know there are some people on here using turbos from Saabs and Porsches. I think DSM eclipse/talons will work also. Do a search for "budget turbo" in the archieves.
Re: (b1788crx)
T3 from a thunderbird, svo mustang, or XR4Ti.
As long as its a .60 compressor you should be fine.
I made 237whp on 8psi with a .60/.48 T3.
B16 that is.
Good luck.
What are you planning to fuel it with?
B16 that is.
Good luck.
New User
Re: (leed)
Go for the one from an SVo mustang late 80's manual model. T3 60 trim is perfect for your app.
Then again, every Mustang SVo guy out there searches for the same thing.
Randy
Randy
Banned
Re: (leed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leed »</TD></TR><TR><TD CLASS="quote">T3 from a thunderbird, svo mustang, or XR4Ti.
B16 that is.
Good luck.
237 at 8psi- damn! for a junkyard turbo
B16 that is.
Good luck.
so the larger trim t3 60 trim did they come on any other cars than the mustang? i htink it really is going to be hard to find this one. i didn't see any 80's mustangf at the junkyard.
ok thanks so pretty much any ford 5 speed turbo. thanks help me out a lot. oh yea what about the ic? should i try and get one from the same car or does it matter?
JDM TEGG
05-28-2009 05:43 PM
turbohf
Northwest (Sales)
03-23-2008 03:14 PM
