D16Z6 Throttle Body questions
Old Dec 10, 2003 | 03:44 PM
5thgencivic's Avatar
Default D16Z6 Throttle Body questions
I picked up my swap from a junkyard and some sensors and things were snapped off the motor I'm wondering how I can get these fasteners out? there's no head on them(they are the same on my cx so I know there was no heads on them to begin with )
And this was bent down and split so I'm wondering how I can get this out as well? I tried turning with the vise grips but it won't budge. What do you guys suggest? Thanks.
Old Dec 10, 2003 | 04:47 PM
sohcvtec1995's Avatar
Default Re: D16Z6 Throttle Body questions (5thgencivic)
i think you have to drill them out. I would juast get a new throttle body.
Old Dec 10, 2003 | 04:52 PM
C uR eX's Avatar
Default Re: D16Z6 Throttle Body questions (sohcvtec1995)
for the tps sensor, get a LFAT head screw-drive and a hammer and just tap on the top or edge of that flatted bolt..just 1 or 2 tap should loosen up the bolt and then you can just twist it out with you finger..
and for the lil tube..just get a plier and twist that thing from side to side and eventually it will come out..this is not that hard..
Old Dec 10, 2003 | 05:00 PM
Default Re: D16Z6 Throttle Body questions (C uR eX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C uR eX &raquo;</TD></TR><TR><TD CLASS="quote">for the tps sensor, get a LFAT head screw-drive and a hammer and just tap on the top or edge of that flatted bolt..just 1 or 2 tap should loosen up the bolt and then you can just twist it out with you finger..
and for the lil tube..just get a plier and twist that thing from side to side and eventually it will come out..this is not that hard..</TD></TR></TABLE>
I wasn't sure if the tube was stamped in somehow or somethin. It's not budging so I'll probably just find another throttle body. Thanks.
Old Dec 10, 2003 | 05:44 PM
I got the tps off, and drilled out the fitting so it popped out. I'll see if I can find a new fitting tomorrow for it...
wfocrx
Mar 25, 2007 08:14 PM
dkrex001
Sep 22, 2006 05:42 PM
BanginNmy4door
Apr 12, 2006 11:25 AM
Crimson_Tide
Oct 21, 2005 04:32 PM
Blackhatch92
Jun 13, 2003 06:48 PM
