I need confirmation on swap details please.......
Old Dec 10, 2003 | 12:49 PM
Team 4R's Avatar
Default I need confirmation on swap details please.......
hello all........ i have some swap questions. i have done a lot of research on these subjects and think i have the problem sorted out, but i would like a confirmation or critique if possible. here's what i have to work with..........
i have two cars, one is a 97 civic ex coupe with stock motor and the other is a 99 civic ex coupe with a b16a2. i plan to pull the si motor/tranny etc from the 99 ex and drop it into the 97 ex...... the first problem is, what wiring harness do i use? if i put in the si one, it should just fire up and go..... the twist is this: the 99 ex is going to receive a 99+ b18c1. the problem: what wiring harness do i use with the b18c1? i believe the gsr harness won't work, so i need to get a civic one.......
my current solution: i will put the b18c1 motor/tranny into the 99 ex with the si wiring harness (with the wire added for secondary butterflies, of course)..... and install the b16a2 motor/tranny into the 97 ex with the d-series vtec wiring harness........ is that feasible? or should i just get a second si wiring harness? any help is much appreciated. thanks in advance.
CLIFF NOTES: 99 ex w/ b16a2 and 97 ex w/ d-series....... b16a2 into 97 ex, b18c1 into 99 ex....... which wiring harnesses to use with each swap?
Old Dec 15, 2003 | 03:01 PM
salbaje's Avatar
Default Re: I need confirmation on swap details please....... (Team 4R)
well Andy you just answered your question.
Use the 99-00 si harness for the gsr swap
Use the 97 sohc harness for the si swap.
Old Dec 16, 2003 | 03:58 AM
VTECVillain's Avatar
You will not be able to switch the harnesses between chassis's due to the OBD2 / OBD2B conflict. Reuse the 97 EX harness on the B16A2 in the 97 EX, then reuse the 99 EX harness on the B18C1 in the 99 EX.
krazyEG
Southeast (Sales)
Dec 1, 2008 11:59 AM
Cprace1
Sep 12, 2005 09:50 AM
Se-rv-Tak
Feb 21, 2004 09:13 PM
pootie.teng
Feb 12, 2004 01:16 AM
boostedblack99
Jul 12, 2003 03:51 PM
