#$%^ HELP!! A/C and BOOST!!! @#$%
Guest
Posts: n/a
Ok here is the problem:
im driving home as usual and my A/C is always off. the **** is turned toward the colder air. anyways im just driving and out of no where white colored gas comes out. at 1st i thought it was smoke and got closer, it was cold air mixing with the hott air, which made fog. so i pulled over to check what was up...nothing. the car isnt acting weird, coolant is fine, JUST the A/C is running and im not turning it on at all!!!!!
someone please help me!!! this should probably be posted in the eg and up forum too. i don't think it has anything to do with the boost. maybe a freon leak? but how do i figure where its coming from???
Open your hood and find the a/c comp. The pulley will turn on and off if the the comp is cycling. You can see it!
A/C comp is right in the front on civics
High humidity causes this and it's normal to see fog coming out of the vents. No worries.
Modified by 97civicdx at 8:25 PM 12/10/2003
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9psi »</TD></TR><TR><TD CLASS="quote">damn car!! someone help me b4 i blow it up...</TD></TR></TABLE>
I have the same problem. But nothing bad's happened that I know of.
markusnjop
Jul 28, 2014 04:40 PM
