#$%^ HELP!! A/C and BOOST!!! @#$%
Old Dec 10, 2003 | 12:15 PM
ek9vboi
Guest
Posts: n/a
Default #$%^ HELP!! A/C and BOOST!!! @#$%
Ok here is the problem:
im driving home as usual and my A/C is always off. the **** is turned toward the colder air. anyways im just driving and out of no where white colored gas comes out. at 1st i thought it was smoke and got closer, it was cold air mixing with the hott air, which made fog. so i pulled over to check what was up...nothing. the car isnt acting weird, coolant is fine, JUST the A/C is running and im not turning it on at all!!!!!
someone please help me!!! this should probably be posted in the eg and up forum too. i don't think it has anything to do with the boost. maybe a freon leak? but how do i figure where its coming from???
Old Dec 10, 2003 | 12:17 PM
b18bturbo's Avatar
Default Re: #$%^ HELP!! A/C and BOOST!!! @#$% (ek9psi)
you can use a freon gas check. The easiest way is go to autozone and get a die to check for leaks pump that into your system and see where it is laking. Did you heat something up and might cracked it
Old Dec 10, 2003 | 12:31 PM
ek9vboi
Guest
Posts: n/a
maybe something with the turbo did it. you you know which hose is the freon one?
Old Dec 10, 2003 | 04:49 PM
ek9vboi
Guest
Posts: n/a
ttt
Old Dec 10, 2003 | 08:35 PM
ek9vboi
Guest
Posts: n/a
help!
Old Dec 11, 2003 | 07:15 AM
ek9vboi
Guest
Posts: n/a
help? ttt
Old Dec 11, 2003 | 07:17 AM
30psi Teg's Avatar
Default Re: (ek9psi)
Is the fog comming from under the hood???
Sounds like a high pressure hose leak.
Old Dec 11, 2003 | 07:24 AM
ek9vboi
Guest
Posts: n/a
i dont think there is a leak. no fog from under the hood either. seems like everything is normal, but the a/c fan is running and cold a/c air is coming out.
Old Dec 11, 2003 | 07:29 AM
falcongsr's Avatar
What is this crap?
$1 says its just the temperature and humidity conditions in your area and that nothing is wrong with your car.
Old Dec 11, 2003 | 07:39 AM
metal-x's Avatar
Default Re: (falconGSR)
i think your fine its just condensation
Old Dec 11, 2003 | 09:10 AM
ek9vboi
Guest
Posts: n/a
ill take that $1 bet. if it is what you say, then y is my a/c fan running constantly???
Old Dec 11, 2003 | 09:26 AM
30psi Teg's Avatar
is your compressor running all the time, or just the fan???
If it is just the fan the you probably just have a bad switch somewhere.
Old Dec 11, 2003 | 09:30 AM
ek9vboi
Guest
Posts: n/a
i think its just the fan thats running.
Old Dec 11, 2003 | 09:32 AM
xenocron's Avatar
A/C relay gone defunct?
Old Dec 11, 2003 | 09:36 AM
30psi Teg's Avatar
Default Re: (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">A/C relay gone defunct?</TD></TR></TABLE>
probably
Old Dec 11, 2003 | 09:52 AM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9psi &raquo;</TD></TR><TR><TD CLASS="quote">i think its just the fan thats running.</TD></TR></TABLE>
sounds normal to me.
i am ever so closer to being $1 richer.
wait you mean the condenser fan not the blower. o well its only a dolla. your car is phucked.
ThreeFourFive
Honda Civic (2001 - 2005)
14
Jun 27, 2013 03:01 PM
gotufeenin
Aug 10, 2010 05:49 AM
gosu08
May 31, 2007 11:00 PM
JDM_Risa
Dec 26, 2005 09:42 AM
ek9vboi
17
Dec 11, 2003 07:26 AM
