Rattling noise
Old Dec 10, 2003 | 09:41 AM
JDM-EJ1's Avatar
Default Rattling noise
Every time I start my car, I hear this rattling noise under my hood. Im not sure what it is, I change my oil regularly, and I take generally good care of my Civic. I have a 94 EX Coupe. Maybe some of the exhaust piping came loose?
Old Dec 10, 2003 | 11:21 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Rattling noise (TunedByHonda94)
ok, your description is a bit vague. is the noise coming from under the hood or under the car? start the car, like normal, and open the hood, listen for where it's coming from and try to describe what it sounds like.
Old Dec 10, 2003 | 11:53 AM
JDM-EJ1's Avatar
Default Re: Rattling noise (vtecb20coupe)
well, when I started my car up this morning. It was under the hood (like the engine bay) not the car... Like, when the car is running the engine shakes a little bit... It sounds like a loose pipe, but Im not sure.
Old Dec 11, 2003 | 09:35 AM
JDM-EJ1's Avatar
bump
Old Dec 11, 2003 | 01:49 PM
jerseydevil's Avatar
get under the car when its cool and shake up the pipes, you can ususally hear where its rattleing. Or you can lightly tap them with a rubber mallet. Quite common for the sheilding to rust out and start to rattle.
Old Dec 12, 2003 | 06:07 PM
92eg6's Avatar
Default Re: (jerseydevil)
when ur warming up ur car look right under the car where the cat is, its probably ur cat, mine makes the same noise
Old Dec 13, 2003 | 11:07 PM
jdmcivicferio's Avatar
That can be way to many things, and you will never find the answer on the internet. Just take it to a shop and get them to check it out.
deemee
19
Aug 19, 2009 08:49 PM
Hellzcivic
Honda Civic (2006 - 2015)
Nov 18, 2006 09:44 PM
asharerin
Aug 25, 2004 12:15 PM
sf89lx
Aug 13, 2004 05:01 PM
Jubi
Oct 16, 2002 10:09 AM
