3rd generation performance parts...
I am suprised by the lack of performance parts for the 3rd generation prelude. However, many parts can be made custom, and some I have never heard of, maybe... Anyway, here is my car parts, or soon to be parts. I want to know everone else with 3rd generation preludes to post what they got, thanks...
Engine
B21A
Maxspeed 92-95 civic intake
DC ceramic header
MSD 6A ignition box
MSD Blaster 3 coil
Magnecor KV85 8.5mm race wires
NGK 8mm wires**
NGK V-power spark plugs
Bosch distributor cap and rotor
High performance oil cap
Apexi N1T
custom 2.25 cat-back exhaust
B&M FPR**
port matched & polished throttle body**
port matches & polished intake manifold**
polished valve cover
reprogrammed ECU
Akimoto silicone hoses**
Redline MTL
custom short shifter
Mugen high compression head gasket**
Mugen high performance radiator cap**
Nissin master clutch cylinder
Nissin slave clutch cylinder**
Suspension
H&R Race springs
Koni Red adjustable struts
ADR Revolutions 17” white w/ custom cap
Toyo FZ4 205/40ZR17
Nissin brake pads
Nissin brake calipers
STP DOT 4**
Genuine Honda suspension bushings**
** Installed soon...
Engine
B21A
DC ceramic header
MSD 6A ignition box
MSD Blaster 3 coil
NGK 8mm wires**
Apexi N1T
B&M FPR**
reprogrammed ECU
Redline MTL
Suspension
H&R Race springs
Toyo FZ4 205/40ZR17
Nissin brake pads
STP DOT 4**
Oh, I forgot to put the ** by it. I havent had it done yet. Take it to a shop that majors in reprogramming ECU, you can have them adjust it anyway you want, such as increasing engine flow...
What have you done to your car - 91LUDESI - do you have a hondaprelude dot com membership.
check out http://www.ludespeed.com that guy specializes on 3rd gen with a similar ls/vetc swap but it's a b21a/ b16 head hybrid.. and he also has a turbo available
i was gonna do the b16 swap on my 3rd gen but then i got the 4th gen vtec.
Graphite Accord,
that's the cool tihng about that site.. the guy, ( who is legit) does all the work in redoing the bolt patterns, oil passages and coolant, all you need to do is find a b16 head and intake manifold and he will do the work on it.. when you get it back, just bolt that sucker in.. he will give you the vtec controller and everything you need.
It will be done, oh yes. I will, be done.
I thought Tom (ludeSPEED) needed car, and I am not willing to drive to California from seattle. When I drop in a new B21A engine, then I think I just might do it. Thanks, I didn't know I just sent him the intake manifold and head.
B21 vtec= allot of work with lots of problems
b21= crap. Go with a b20 or the jdm b20a5 to avoid the oil burn problems the b21 has due to the frm. If you're feelin froggy, you can fab up some mounts to throw in a b18c.
Reline MTF: Don't use it! Its way too slick for our trannies.
A great write up.
