ek tein flex users: what dampering setting are you guys using?
Old Dec 10, 2003 | 05:18 AM
jeremy.'s Avatar
Default ek tein flex users: what dampering setting are you guys using?
curious to see what you ek drivers are running on the streets....0 being the hardest. i'm running the standard 8 front and 8 rear right now until the springs start to settle...
Old Dec 10, 2003 | 06:12 AM
thinkbrianthink bu's Avatar
Springs settle when you put the car on the ground.
There is no transition period. If they 'settle' anymore after the initial compression then its called 'sagging'.
Old Dec 10, 2003 | 07:41 AM
jeremy.'s Avatar
Default Re: (thinkbrianthink)
sorry that's what i meant
Old Dec 10, 2003 | 09:06 AM
R you serious's Avatar
Default Re: ek tein flex users: what dampering setting are you guys using? (ek_jeremy)
run what ever feels best. i personally like a little bit of a stiff ride, so i keep it on 8/8 on the street and kick the rear up to 11 for the track.
Old Dec 17, 2003 | 02:17 PM
moto27cm's Avatar
I run about 8 all around on the street. On the AutoX course, I run the back all the way in (16) and the front at about 12.
Old Dec 17, 2003 | 02:56 PM
Damon B.'s Avatar
Default Re: (moto27cm)
right now I', runing 10/10...
Old Dec 17, 2003 | 06:53 PM
blackspoonem's Avatar
Default Re: (CleanSi)
I run 8 all around feels good in my civic
Old Dec 17, 2003 | 07:30 PM
WangChung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">curious to see what you ek drivers are running on the streets....0 being the hardest. i'm running the standard 8 front and 8 rear right now until the springs start to settle...</TD></TR></TABLE>
i have no experience with teins, but from the other guys suggestions, "0" sounds like the softest setting, 16 being the stiffest.
crashedacar
Feb 15, 2008 09:44 PM
macsmurray
15
Feb 27, 2005 06:11 PM
IS3Fifty
Jul 7, 2004 12:38 PM
VTEC-DA
22
Aug 27, 2002 06:17 PM
