Just bought a 2000 Type-R and have some quesions
Old Dec 9, 2003 | 07:31 PM
typeR#0427's Avatar
Default Just bought a 2000 Type-R and have some quesions
whats up, I am the proud new owner of a 2000 PY ITR. I found this car and kinda bought it on an impulse. I typically don't buy cars that have been modified by someone else. But I figured what the hell. Well I do have some questions.
The car has a VAFC, and tonight when I went to lunch I noticed that the check engine light was on and the VAFC was off. And the rev limiter is coming on at 5600RPM's right when the VTEC comes on.
This is obviously not right. What do you guys think, do I just need to tune the VAFC, or is something else wrong.
It has a JDM front on it and I also noticed that the front turn signals do not work. I am a little stressed, because the last thing I wanted was to drop a bunch of cash and run into problems.
Your help and critisim is appreciated. Thanks in advance
Old Dec 9, 2003 | 07:45 PM
machgo5go's Avatar
Default Re: Just bought a 2000 Type-R and have some quesions (hamB18C1)
I had similar set up on my previous 97CW R with the Field controller with harness.
Its a hit or miss set up with the Factory OBD2 in our ECU. It works fine for a while then one day check engine light comes on and OBD2 will go into fail safe mode by not letting u rev over into VTEC range. I had to reset ECU by removing my battery cable and then everything ok. I got sick of this situation so I removed the Vtec controller which did nothing for stock motor. Now I gave up messing around with my 00FBP R and just enjoy the ride.
Old Dec 9, 2003 | 07:47 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">whats up, I am the proud new owner of a 2000 PY ITR. I found this car and kinda bought it on an impulse. I typically don't buy cars that have been modified by someone else. But I figured what the hell. Well I do have some questions.
Your help and critisim is appreciated. Thanks in advance </TD></TR></TABLE>
i'd get rid of that vafc junk.. that should be an easy way to solve this problem and avoid other problems.
Old Dec 9, 2003 | 07:51 PM
Mr Boston's Avatar
Default Re: Just bought a 2000 Type-R and have some quesions (vtec.dc2)
Yeah I would jus get rid of the vtec controller and sell it. I'm pretty sure the previous owner didnt install it corretly.
Old Dec 9, 2003 | 08:08 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Just bought a 2000 Type-R and have some quesions (Ngo Power)
Are there other mods that prompted the previous owner to install a V-AFC?
At any rate, triple-check all the ECU/V-AFC wiring. The fact that your front turn signals don't work suggest that the previous owner either didn't give a ****, or was just trying to dump a problem child.
Good luck.
Old Dec 9, 2003 | 08:10 PM
typeR#0427's Avatar
Thats exactly what I was thinking. I don't really see a need for the VAFC anyways. Unfortunatly the car is going to be a daily driver. I would like to keep it in the garage, but I can't. Plus its my wifes X-mas present. I am going to remove the unit tomorrow.
I did however notice that the fuse box cover was off. And the dealer had just detailed the car. I hope that it did not fry anything. So when the light is on, the car goes into safe mode? Thats rad. I also have a clifford alarm, does that have a wierd setup also. I have only dealt with other systems.
Thanks for the advice, and if you know anyone that wants a VAFC I have one. I am stoked to be a part of the family!
typeR#0427's Avatar
Lets hope it wasn't a problem child. I did get somewhat of a warranty with it
Old Dec 9, 2003 | 08:26 PM
itsallmotor's Avatar
From: rigged and ready., WashingtonD.C./FlagstaffAZ/TempeAZ usa
hey im sorry to hear your already having problems, but i've heard of lots of people on ht having problems w/ v-afcs and it was generally user error/installation or faulty wiring, i wouldn't go ahead and sell it quite yet though, checking the wiring connections and maybe even checking voltages and resistance w/ a multimeter would not be a bad idea though, hope it works out so i can see her and get a ride soon, im still in shock man
Old Dec 9, 2003 | 08:36 PM
typeR#0427's Avatar
Default Re: Just bought a 2000 Type-R and have some quesions (hondavtecfanatic)
Thanks homey, I have to move the controller to the glovebox anyways, they put it on the dash So I am going to check out everything tomorrow.
The previous owner had a RX-7 that was in sport compact car a while back. So I think that he had everything done right, at least I hope. I hate wiring, oh well, I have a nice car.
Old Dec 10, 2003 | 05:10 AM
EEK's Avatar
EEK
well if you wanted to sell it..how much?
Old Dec 10, 2003 | 05:54 AM
Splat's Avatar
Default Re: Just bought a 2000 Type-R and have some quesions (EEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EEK &raquo;</TD></TR><TR><TD CLASS="quote">well if you wanted to sell it..how much?</TD></TR></TABLE>
Damn vultures
Old Dec 10, 2003 | 06:09 AM
Willard's Avatar
why get rid of the vafc? it is hooked up correctly? crimp connector crap?
Solder the vafc in correctly and make sure it is set up properly.
They do work... you just have to know how to use them.
https://honda-tech.com/zerothread?id=511707
Old Dec 10, 2003 | 06:40 AM
EEK's Avatar
EEK
Default Re: Just bought a 2000 Type-R and have some quesions (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
Damn vultures </TD></TR></TABLE>
lol..actually i have one...not in the car though...on the other hand jdm R pistons..100 bucks anyone? they have 9k on them
Old Dec 10, 2003 | 07:11 AM
Hybrid 350GT's Avatar
Make sure the settings on the VAFC are correct. Make sure the Engine is set to 4/. Also that the senor setting is 6 in 6 out. If these 2 things are not set correctly it will cause the CEL and the car will run exactly how you described. This happened to me.
Old Dec 10, 2003 | 07:28 AM
Lucky-R's Avatar
Default Re: Just bought a 2000 Type-R and have some quesions (DOSPOWND)
congrats on your purchase. sounds like a nice one to buy at an impulse. besides the vafc, invest in security. check out the other thread about the stripped R...sad
Old Dec 10, 2003 | 07:42 AM
mstewar's Avatar
none of the turnsignals work, or just the front ones don't? Do the blinkers in the dash blink double fast?
Old Dec 10, 2003 | 12:06 PM
typeR#0427's Avatar
Default Re: Just bought a 2000 Type-R and have some quesions (mstewar)
The front blinkers don't work, the rears do. The blinkers do double flash. The spot were the blinkers are suppose to be are empty, probably an easy fix.
I am maybe keeping the VAFC, I am not sure, but if I did sell it I would ask
$200.00 shipped, looks like thats what they are going for here.
I took it to the dealer and cleared the code, thats exactly what the CEL was. Going to tackle that tomorrow.
Old Dec 10, 2003 | 12:25 PM
r573's Avatar
good s.... good luck with your new R lock it up at night
Old Dec 10, 2003 | 12:30 PM
jdmspoonitr's Avatar
Default Re: (r573)
The guy probably did a hack job on the install. There is nothing wrong with the VAFC most likely. Just redo it.
And as for the cornerlights, you just need new bulbs. I'm sure you figured that out already though.
Old Dec 10, 2003 | 12:39 PM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">The front blinkers don't work, the rears do. The blinkers do double flash. The spot were the blinkers are suppose to be are empty, probably an easy fix.
yep.. lenses, sockets and bulbs.. then you're all set..
Old Dec 10, 2003 | 12:42 PM
fuck honda-tech's Avatar
Default Re: (jdmspoonitr)
good luck with ur car and keep an eye on it at night
Old Dec 10, 2003 | 01:07 PM
dandc2's Avatar
Default Re: (epsom salt)
my check engine light is on, but my vtec still engages.... and the car runs great....
i think it might be because of the high flow cat... but im not sure
Old Dec 10, 2003 | 01:16 PM
tc's Avatar
tc
Default Re: (dandc2)
Check out Apexi's website to make sure all the proper wires are connected. Most likely, some of the wires came loose...
tc's Avatar
tc
Old Dec 10, 2003 | 01:57 PM
IvTecR's Avatar
Default Re: (tc)
b4 doing anything, secure that baby up coz jdm fronts are thieves' bait
